Question about Echo Garden
Cannot get the echo chainsaw to start. First time using it, was given to me by a friend with no instructions
    Top Expert:
  • Echo Master
  • 78,010 Answers
Does it have spark? if you spray starting fluid into the air cleaner does it start?
Posted on May 05, 2017
I have the weedeater GT-225 and have given it some pretty hard use for about a year. i filled it today with premixed gas/oil (after i shook it well) and it started right up. however, whether i have the...
This is fuel starvation, start by replacing the fuel filter in the tank, on the end of the fuel hose, check the fuel hoses for leaks and cracks.
Jul 17, 2011 | Echo Garden
I have a echo cs 4600 chainsaw & am having problems with starting the saw. When it sits for awhile it starts up, but when you shut it off it will not start again. I check the plug and it is wet with...
First thing to do is a new plug.Also clean the air filter.Might help?When you take the plug out.Look down the hole to see if there are any scratches on the cylinder?usually muffler side is where they will be if any.I had one doing the same thing.It was blowed up.Needed a new piston and cylinder.Hope yours don't?
Mar 06, 2011 | Echo Garden
Are you pumping the primer bulb until fuel flows into the bulb, setting the choke, and the fast idle is being set? Set the choke at half position after the first 'pop' and don't touch the throttle until it starts running. If you are doing these things per the instructions, take the machine back for warranty adjustment. Hope this helps!
Nov 03, 2010 | Echo CS600P Gas Chainsaw 20 Inch
Info. on old JD chainsaw
Echo made a lot of the quality JD saws, then they went cheap and used the old homelite brand, Call maureen at outdoor equipment dist in raleigh NC, she can give you whatever info you8 might need.
Jan 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Wanted manual for echo 320 vl chainsaw
Ordinarily I would send you here for a download but your saw is not listed.
Click “2. MANUALS, Catalogs, MSDS and Installation Instructions”
Then “Operator’s Manuals/ Parts Catalogs/ Safety Manuals/ ~more~”
Please try here:
For all that follow you please include a request they add literature your saw to to the list. HTH
Nov 29, 2009 | Echo Garden
Echo 14 in chain hard to start - won't keep running and began to smoke
Hard starting can sometimes be caused by a clogged air filter which is where I would start. Clean the filter, if you have the operators manual it explains how to do this, if you don't have the manual check Echo's website to see if you can download one. Next check the manual and see if the carburetor can be adjusted, but be very careful to follow the instructions in the manual exactly or you could do irreparable damage to the needle jets in the carburetor.
Aug 20, 2009 | Echo 30.1CC Chainsaw With a 14 and...
I need a service manual for a Benchmark 2.3 chain saw.
The model you provided does not cross to an exploded parts list. All Echo manuals can be found here:
I can do no better given the information you provided. GL
May 11, 2009 | Echo Garden
Chainsaw won't start
Time to get out your trusty tool kit. Remove the side cover assembly and look at the recoil assembly. You should see a pair of fingers that when you pull the cord move toward the center. If the fingers are there and not broken, make sure they move when you pull the cord. clean them if dirty or have foreign objects (like sawdust) around them. If the fingers are broken, replace them. You should be able to purchase them from your local saw shop.
Apr 18, 2009 | Echo 30.1CC Chainsaw With a 14 and...
Echo CS-302 chain saw with no instructions (Inherited)
the echo cs302 is equiped with an automatic oiler that lubricates when the engine is running the manual states the unit runs on a 20:1 mixture 89 octane fuel with 6.4 oz of tcw3 oil per gallon
Apr 10, 2009 | Echo Garden
Open Questions:
Garden Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Are you an Echo Garden Expert? Answer questions, earn points and help others
