Question about Keurig Coffee Makers & Espresso Machines
My Keurig 2.0 will not brew,when you press the button it goes right to do not lift hot. does nothing after that
    Top Expert:
  • Keurig Master
  • 75,066 Answers
Best to just replace the machine.
Posted on May 05, 2017
Keurig 2.0 After brewing it continues to have the brew sound and the screen says do not lift, hot.
Call Keurig customer service and request a replacement. It is defective, and under warranty. They will ship a new unit factory direct, no charge.
Jan 11, 2015 | Keurig Coffee Makers & Espresso Machines
Vue 700 brew length problem
Honestly, contact Keurig. Why would you try to fix something that is only 10 days old? Keurig has awesome customer service. You can contact them here:
http://www.keurig.com/contact-us
Dec 13, 2013 | Keurig Vue Brewing System
Will not brew . says ready to brew but when I press brew button nothing happens
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101]][[]
Aug 19, 2011 | Keurig Ultra In Home Single Cup Brewer...
Everything seems to be right, says ready to brew, press brew, says brewing, then nothing ever happens
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 08, 2011 | Keurig B70 Coffee Maker
Pressed the brewing button and machine says brewing but nothing come out
heatman101
May 28, 2011 | Keurig Platinum B70 Coffee Maker
When i press the brew button the display reads "BREW" but nothing happens - also it only brewed 1/2 a cup the other day
heatman101
May 15, 2011 | Keurig B60 Coffee Maker
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
My keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Jan 02, 2010 | Keurig Special Edition B60 Coffee Maker
The machine says REady To Brew- the lights flash and i press the button to brew. It says "brewing" but nothing ever comes out and then it goes back to "Ready to Brew".
Mine does this all the time. When it does, I tap the top of the machine and the coffee comes out. I don't know if it will work for you, but it works every time for me. It's like there's a small clog or something.
Nov 01, 2009 | Keurig Special Edition B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
