Question about Orbit Hardware & Accessories
Where can I get a manual for Orbit sprinkler timer model #91022, 12 station
mydogisk
  • 50 Answers
SOURCE: Solenoid on one station, sprinklers on another, cant turn both on
the should be a pump or master solenoid connection inside the controller
Posted on Apr 13, 2009
protek480
  • 1723 Answers
SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Posted on Jul 02, 2009
SOURCE: I have an Orbit WaterMaster Sprinkler control, it
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Posted on Jun 23, 2010
SOURCE: I have a Orbit 57161
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
SOURCE: How do I get a
Welcome To FixYa
I was able to locate a manual for your timer. Go to this website
http://www.orbitonline.com/lib/media/57894-24%20rA%2812%291.pdf
Please note that this is in PDF format which means that your computer needs to have adobe reader installed. If you dont have that you can download it here
http://get.adobe.com/reader/
If you have further questions just reply back and I will be happy to assist you
Hope this Helps
Posted on Jun 04, 2011
Getting sprinklers to come on
Is it a one way valve? If so you may need to turn it around, if it was just installed from new... make sure that the dust caps are not inside the valve and obstructing the line
Jun 02, 2016 | Orbit Hardware & Accessories
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
"my orbit easy dial 6 station quit working in auto
Does it work manually? If so, which is rare and almost unheard of I would replace the timer. You can't buy a less expensive timer $20 for a 4 station. Which explains why it is not working. If it doesn't work make sure it is plugged in and outlet has power.
Aug 11, 2013 | Orbit Irrigation 57856 6 Station Easy Dial...
Manual pdf
Copy following link for links to Orbit and other sprinkler and irrigation timers on market today:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment for followup help.
Jun 11, 2013 | Orbit 57882 9 Station Super Dial...
Download operators manual
Question posted under sprinkler timer:
Copy following link for general list of current sprinkler timers, digital and mechanical, and links to each brand and possible manual for each:
Oct 19, 2012 | Orbit 57882 9 Station Super Dial...
I have city reclaimed water source for my sprinkler system. My problem is I connected the waterlines to the solenoid (1) and then the zone index valve (4 zones ), then i wired the solenoid to my spr
What model number of timer? I have to see exactly which timer you have to answer question.
What wire goes where?
Are you using 120Volts?
What is output voltage of timer?
What voltage is solenoid? 24Volt or 120Volt?
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
Aug 09, 2012 | Orbit Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Can i get online instructions on how to program my
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
Jul 22, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Hardware & Accessories Logo
63 people viewed this question
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
appman67
appman67
pawnpower
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
