Question about Philips Televison & Video
Philips Flat TV locks up on one channel and won't change
Hi, We have a Philips Flat TV Model number 19PFL5602D/05, bought 14 months ago for digital switchover, which is only used occasionaly. It's just started to lock up on one channel, not responding to either remote channel change or the direct tv button channel change. Can you tell us why?
Cheers!
Peter G.
Hi i need help cause my philips47pfl7704dif7 when i turn on the tv it just turn blue and wont let me change sources or channels . Help me.
Posted on Jul 01, 2013
SOURCE: tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
Posted on Oct 14, 2011
SOURCE: Hisense flat screen has locked
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That did it for me. After I shut it off I had to do it one more time but it did the job. A friend of mine gave me the tv for free because nobody he new could figure it out. I took it home, got lucky, and figured it out in about ten minutes.
jb
Posted on Sep 03, 2008
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
  • 1156 Answers
SOURCE: Hi my philips flat tv won't turn on? The green
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
You can change the power board yourself , it very simple, but must taken to avoid high voltages in panel, please note
Posted on May 06, 2011
Issue was with the HD channels only.
Updated the firmware of the TV to ver 2.
Now the TV will stutter for a second when changing to a HD channel but it no longer locks up.
Posted on Feb 17, 2008
Hi! i have a philips 20pf4121/05 flat tv.it won't turn on and green light is flashing few times and that s it.do you know how i can fix the problem?
Not likely to be a do it yourself repair. From the model number it is a 20 inch and if the power supply board is bad may not be economical to fix not to mention quite often on the smaller sets parts do not exist.
Aug 29, 2012 | Philips 20PF4121 20 in. EDTV-Ready LCD...
Philips 26pfl5522d/05 TV Channel issue
Just been on Philips Forum and there is a possible very simple solution. Press and hold the MENU button ON THE TV for about 20 secs. This should factory reset TV and allow storage/retrieval of channels to the '8k' store. See this page for more detail:http://www.supportforum.philips.com/en/showthread.php?1366-26pfl5522d-05.
Now I have to ring my Dad who has exactly this problem!
Apr 03, 2012 | Philips Televison & Video
Philips 42pfp5532d 05 plasma tv won't store tv channels. when turn off then back on has to scan for tv channels again.
I had the same problem a little while after the digital change over, channels were all lost struggled to get the set up menu up but when i did i retune the channels as soon as you turn the tele off there lost again. but it works if you leave the tele on standby. 2 people have told me it's the battery in the tele itself.
Aug 26, 2011 | Televison & Video
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
My philips tv flat screen keeps shutting off and a red flashing code starts blinking?
Not sure what code since you didn't say, but here is the code breakdown.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 27, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
MODEL NO 32PPFL5522D/05 PHILIPS FLATSCREEN I NEED TO GET THE CHILDLOCK OFF TO RESET DIGITAL CHANNELS FOR 30/9 RETUNE
for some Philips the codes are
Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
some are 162596
These TVs have both a service-override mode which temporarily over-rides all user settings including parental lock, as well as a 'settings mode' which lets you change anything, including things that can mess up your TV. The above code is the service code, afaik.
Oct 20, 2009 | Televison & Video
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
Philips 32 LCD TV 32PF9541 Black Screen
Sounds like a temperature problem if it takes a while for the problem to happen there are several things u can try and figure it out yourself. 1. Remove the back cover of the tv and turn the tv on. 2. use a hair dryer and apply heat to various boards of the lcd (inverters, power supply and scaler) while applying heat to see what board reacts and makes the tv go dark. More than likely its a defective LCD panel and its just as easy to send it back and get a replacement TV.
Apr 28, 2008 | Televison & Video
No signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Apr 26, 2008 | Televison & Video
Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Sep 19, 2006 | Philips 28PW6506 28" TV
Televison & Video Logo
1,710 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
