Question about The Audio Players & Recorders
How can I disable the (Texecom Premier 412/832) chime for a particular zone? While it stays on for the rest of the zones.
SOURCE: Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Posted on Dec 05, 2007
SOURCE: Multi Zone code Samsung 5600 DVD VCR Combo
Try this site:
http://www.videohelp.com/dvdhacks/samsung-dvd-v5600/7031#26074
Particularly the entries from:
Region code hack posted by Anthony Green, September 10 2006:
And
Region code hack posted by ZoidsGodzilla, November 22 2006:
Good luck
Posted on Jan 08, 2008
informatica
  • 1114 Answers
SOURCE: Time zone
Hi - You can download the manual from the link underlined in blue below:
Chaney
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2008
SOURCE: Honeywell TZ-4 Misbehaving
there is a "zone a lone" switch on the upper right side of the panel. Make sure it is in the "occupied" position. I believe that is up. If that doesn't work reply back.
Posted on Sep 18, 2008
  • 17 Answers
SOURCE: I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Posted on Jun 25, 2009
Dsc pc 1555
Is this a Laptop problem or a home security question? If home security, is the door a wired or wireless zone? A Chime on the door, is that on the control panel or a local chime at the door?
Are you absolutely sure zone 5 is that door? Is your bypass zone activated? You should be able to hold arm to arm it anyway.
Nov 16, 2013 | Computers & Internet
We have an NX-148E keypad. Our building has 4 doors alarmed to the panel and the Chime sounds when any of the doors is opened. Is it possible to set the Chime only to sound when 1 of the doors is op
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
Oct 03, 2012 | GE / Caddx Networx Programmable LCD Keypad...
How to set the alarm
These are the instructions posted on the Armitron website. I hope they help.
1. From Time Telling Mode, press 'B' twice to enter the
Alarm Mode.
2. Press 'A'. Alarm Hours flash. Press 'C' to advance the
Alarm Hour.
3. Press 'B'. Alarm Minutes flash. Press 'C' to advance the
Alarm Minute.
4. Press 'B'. Alarm Time Zone flashes. Press 'C' to select
either Time Zone 1 or Time Zone 2.
NOTE: The Alarm is available in one Time Zone only.
5. Press 'A' to end set sequence.
6. Press 'B' to return to Time Telling Mode.
ACTIVATING THE ALARM AND HOURLY CHIME
1. While in Alarm Mode, press 'C' to activate the Alarm.
The Alarm symbol appears to indicate the Alarm will
sound at the preset Alarm Time for 20 seconds or until
'A', 'B' or 'C' is pressed.
2. Press 'C' again to activate the Hourly Chime.
"CHIME" appears to indicate the Hourly Chime will sound
every hour on the hour.
3. Press 'C' again to deactivate the Alarm.
4. Press 'C' again to deactivate the Hourly Chime.
5. Press 'B' to return to Time Telling Mode.
Apr 12, 2011 | Armitron Digital Sport #40/8095SIL Watch
My key pad is displaying not ready chime only
Not Ready means one or more of your zones is faulted. Pressing the * key on the keypad will display the zone or zones that are faulted. A faulted zone can be a door or window open, a motion detector "seeing" movement, and so on. It will also display a description of the zone. Chime means the chime feature on the keypad has been enabled. Any perimeter or entry/exit zone that faults will cause the keypad to ding three times. This can be turned off by entering your 4 digit code and pressing the 9 key. Doing so again will turn it back on. The link below is for the user manual for an Ademco Vista 20P panel.
Hope this helps.
http://panelguides.com/panel-guides?task=view.download&cid=1181
Mar 22, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
I can't get the system to chime when the door is opened. How do I turn chime mode on?
Enter your code and the 9. This turns on chime mode. If it still does not chime the zone is not programmed for a entry exit or perimeter zone.
Dec 25, 2010 | Honeywell Ademco 6160 Alpha Keypad Vista...
Have ADT 3000 series alarm system - would like to set it to max
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
Feb 25, 2010 | GE Security Simon 3 Wireless Home Security...
Yamaha RX-V757 Receiver
i thinck that you have internal short circuit in wiring of zone 2. and you must fix this wiring first befor you go ahead -or you disable it by disconnecting it-and the rest of the system will work fine.
Jul 26, 2008 | Audio Players & Recorders
Day-Light-Savings Time
I have the same problem exactly and am in the Easter time zone too, so have not other solution.
Mar 12, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
GE simon security system
Depends. Do you mean the chime? If all that is missing is the chime whenever a zone is tripped then simply press the CHIME button on the front panel. If it is lighted solid red then your chime is on and it will talk to you. If chime is off then it wont talk to you at all when a zone is tripped. Good luck.
Mar 09, 2008 | GE Security Simon 3 Wireless Home Security...
46 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
