Question about Power Computers & Internet
Victron inverter suddenly switched off with 76% battery full and did not switch to mains. there is no power outage on mains. What do I do to get it to switch on and go to mains? Please help
SOURCE: My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Posted on May 30, 2008
  • 6 Answers
SOURCE: ERROR CODE SC101
SC101 indicates and exposure lamp problem. To try and correct, turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left.
Posted on Jul 09, 2008
SOURCE: Heart Freedom invertor 25/12 - cannot get invertor to function
You are correct, if the unit is wired correctly, all you have to do is turn the inverter on.  The unit should make a bit of noise when the inverter is turned on.
Posted on Feb 08, 2009
rj_8017
  • 22 Answers
SOURCE: LG flatron L1730S: Starting problem
change the power section capacitors..
Posted on Feb 10, 2009
raingamj
  • 2148 Answers
SOURCE: nokia 1600 suddenly battery low
Sometime replacing of battery is right, it is more costly So you better go to mobile tech or you can do this.78bf4b2.jpg
Posted on Aug 13, 2010
De inverter switches off indicating low Batteries while according to my monitor ( xantrex charge ) battery bank is 100%. How can I help help it?
use a voltmeter and measure the voltage AT THE INVERTER'S Battery terminals and see if its over 11 volts. You could have a loose connection or a bad cable creating a voltage loss.
Jul 26, 2015 | Victron ENERGY Quattro 24/5000/120-100/100...
Can't find the transfer switch, and could it go bad. Shore power and generator power works to the main panel box, but won't charge coach batteries
although it is possible to do separately most times the transfer switch is internal to the inverter , and the fact you mention that inverter is not charging batteries tells me your fault lay in the inverter all or part of it is not working , look at it carefully these have sometimes two reset breakers on there cases
Jun 01, 2015 | Inverter Electronics - Others
Invertomatic victron imv ups
Malfunction of input circuit: voltage delivered is too low. The batteries may
be faulty or depleted. Wait for a few hours, leave the UPS switched on
If absence of input power (utility failure, maintenance work) is expected to last longer than a few hours, switch
off the UPS to save battery power. If the UPS input power is absent for several days and the UPS remains on
under no-load conditions, the batteries can be discharged very deeply, resulting in a short battery life time
Apr 22, 2014 | Computers & Internet
Can I operate a light on a 12v battery while it is being charged with a guest 2606A
yes, but a slightly depleted battery will take longer to reach full charge if the current is being drawn from it.... although if it's an LED light and efficient radio the current draw will be almost negligible or hardly enough to notice.
but why would you want to run mains electrical items from a battery that's plugged into the mains?
it's much more efficient to use mains electrical power for your devices until there's a power outage (this is where the inverter is really needed) or you need mains power in the middle of nowhere.
if you absolutely want to go down this route maybe an old UPS would come in handy, it will continue to output mains power in the event of a power outage.... just connect your battery in place of the old dead one (your 32Ah won't fit in the box, just use heavy cable) UPS boxes hold a 12v battery, it's a simple hack.
Nov 23, 2017 | Electronics - Others
In my home using 100AH battery for inverter , want to know wht happens if the baterry is not connected to inverter ? Is battery life decreases..? or WHAT ELSE WILL HAPPENS TO BATTERY ..? plz give an...
It depends upon the type of UPS.
A true UPS requires a battery to be connected to the inverter at all times. Mains power is used to charge the battery constantly and battery is required to continually supply power to the inverter which then converts the voltage to mains supply voltage.
A lower powered and cheaper type UPS areswitch-over types, when the mains supply fails, the UPS switches over to thebatteries and the inverter in milli-seconds which then supplies mains power to thecomputer and peripherals.
This type UPS may operate without a battery, but it depends upon the design of the UPS and the battery error detection system In most cases I doubt it can operate without a battery. You can try the UPS without a battery, make sure the battery terminals do not short against each other.
Dec 21, 2011 | Televison & Video
Can i have all the basic details of UPS system
UPS come in two types, lower powered cheaper types are usually switch over power.
These units senses a power outage and then switch over to the battery power to generate mains supply. The switch over occurs in milli-secs and does not affect the computer.
True UPS types constantly run off battery power to generate mains supply so there is no switch over time lag. These units are higher powered and higher costs units.
Both type of UPS have the same components.
Battery charger.
Batteries
Inverter that converts battery voltage to mains voltage
Electronic controls
Dec 16, 2010 | Emerson PowerSure Personal 500VA...
Sir after changing the battery ups worked well one day and the next day onwards when i pressed the switch red and amber lights blinking and the upc trips with beep sound .kindly give the solution
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper KVA type UPS are switch over types, when the mains supply fail, the UPS switches over to the inverter in milli-seconds which then supplies mains power but the power waveform is a pseudo sine wave (ie not a true sinewave. A faulty inverter circuit won’t deliver power when the mains supply fails.
The true UPS types are usually the higher KVA units (over 1500 VA) that supplies uninterrupted mains power. The mains power is connected to a charger which charges the batteries and the inverter draws power from these batteries and converts it to true sine wave mains power therefore there is no switch over time lag from the mains to the battery.
Oct 16, 2009 | APC Computers & Internet
My ups is switching off itself immediately the mains goes off.the battery is okay with 13v.
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and enviromental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only a float voltage and a true indication of the battery voltage needs the batteries to be tested under a load. there maybe one battery that is faulty and causing the whole battery system to fail.
These lower powered and cheaper KVA type UPS are switch over types (when the mains fail, the UPS switches over to the inverter in milli-seconds to supply mains power). It is a possibility the inverter circuit is faulty and when the mains power fails the inverter does not switch over.
The true UPS type are usually the higher KVA units (over 1500 KVA units) that converts mains power continuously via the inverter circuit. The mains power charges the batteries and the inverter drawing power from continuously from the batteries (therefore there is no switch over time lag from the mains to the battery.
Sep 25, 2009 | MGE Pulsar Ellipse 800 (89363) UPS System
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
Computers & Internet Logo
Top Power Computers & Internet Experts
waruna
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
