Question about Ricoh Office Equipment & Supplies
I want to know what this error code means SC05-60 of a Ricoh CP450 copyprinter
  • 990 Answers
SOURCE: Black spots and lines on papper
Hello sir; Only thing you need to do is change a drum cartridge.
Posted on Jun 03, 2009
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
SOURCE: ricoh hq9000 copyprinter drum leaking
We have had similar ink leaking problems in the past. We found this company- arico1 . We send our type 90 drums there and they refurbished them. They've been real good to us.
Posted on Apr 21, 2010
  • 903 Answers
SOURCE: Ricoh 3310l fax shows error code 0390H in display.
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Posted on Jun 14, 2010
  • 1833 Answers
SOURCE: I have a copyprinter Duplo DP 460H which gives
There are no solutions right now for your problem. You have to wait for this or you can contact any tech person.
Posted on Apr 11, 2011
Ricoh 1813. Error code c551
The Ricoh copier error code SC551 / 551 is a fusing thermistor 1 error code.
It can mean:
1. The thermistor is not connected
2. The thermistor connector is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Oct 03, 2017 | Ricoh Office Equipment & Supplies
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
E22 code
E - 22 Scanner home position sensor error.Possible causes:
scanner home position sensor failure
scanner motor defective
incorrect scanner ddrive wire position
Remove the exposure glass and verify the wire and the sensor actuator.
Turn DIP switch 101 - 1 ON and press START key to run free the scanner.DIP switch is located on PWB board in rear area,remove the rear cover.
Feb 07, 2013 | Gestetner - 5309L CopyPrinter Copier
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
SC 107 code
The error SC107 means Lamp regulator malfunction.The possible are
--Lamp regulator defective(Pcb)
--Exposure lamp open
--Optics thermoswitch open
--Scanner control board defective or poor connection
This is a very old machine so I hope you have some luck solving the problem
Feb 24, 2010 | Ricoh Office Equipment & Supplies
I have error code sc329 on my Aficio/ricoh copier. What does it mean and how to fix it. Please help. Thanks
In some models this code means that the laser has aged and must be replaced.
But he would be interesting to know that model is for being safe of this.
Sep 13, 2009 | Ricoh Office Equipment & Supplies
Jun 03, 2009 | Brother DCP 7010 Multifunction Laser...
Ricoh hq9000 copyprinter drum leaking ink any help would be appreciated
Mar 18, 2008 | Computers & Internet
Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Jan 24, 2008 | Ricoh Aficio CL2000N Laser Printer
23 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
