Question about Hardware & Accessories
Need manual for timer #uttnid001 - Hardware & Accessories
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
Need instructions to program noma timer 052-8873-0
Copy following link, and scroll down and find same-similar timer, then click on manual and follow instructions in manual, then save manual to your computer, or open manual and add to your homescreen on phone or ipad, then when needed again search phone or ipad for manual or .pdf.
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
Gene
Dec 09, 2013 | Hardware & Accessories
Instructions for timer
Timer is not identified:
Copy following links to identify same-similar timer and download manual:
Add a comment and describe timer in detail for possible identification
May 09, 2013 | Hardware & Accessories
Need manual for timer dtsx-240-hc
More information is needed.
Review options below:
1) Add a comment and describe timer in detail for best possible answer.
2) DTSX timer appears to be older-style GE/Grasslin or Intermatic/Grasslin/Frost King defrost timer with selectable voltage and F 3 1 2 4 N X wiring terminals.
Open following links to identify timer and download possible manual
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#defrost
http://waterheatertimer.org/pdf/DTMV40-instruction-manual.pdf
Additional resources explaining more about defrost timer operation:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8145
3) Tork makes DTS series timers with 1, 2 and 4-channels:
Each channel can be programmed separately to control different loads with different on-off schedules.
Timer clock is 120Volts, but dry switch terminals can be wired to control any voltage load.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DTS
Sep 28, 2011 | Hardware & Accessories
GE digital timer DT300 need a free manual
Question posted under GE 15004 timer.
Open following link to identify Intermatic DT300 timer and download possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
Open following link to identify GE15091 timer and download possible manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
If the free information does not match your timer, then add a comment with clear description of timer for possible identification and manual.
Sep 23, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Need a manual for digital timer DT300GE
Timer is not identified.
If the information does not match your timer, then add a comment with clear description of timer for possible identification and manual.
Sep 23, 2011 | Hardware & Accessories
Brinks 44-1030 manual i need a pdf of the instruction manual for brinks light timer model number 44-1030
1) Can you describe the timer in detail?
The buttons and the dial, shape, if it plugs in or is programmable, whatever you can think of to illustrate what timer looks like.
I have extensive files on timers
Most brinks timers are versions of other timers, and manuals exist for those timers.
Add a comment with the information, and I will post a manual if timer matches other brands.
2) You can open following link and see if your timer appears on the page:
Manuals appear for each timer on page with a few exceptions.
3) Another step would be to buy the 44-1030 at Walmart and scan the manual into .jpg format.
Download Cute-writer the free pdf software.
Print your .jpg image but select cute-writer as the printer.
Instead of printing, the software makes a pdf manual.
I use this technique when I need a manual
Title your new manual and post it on the internet for sale.
Return the timer for a refund.
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you describe timer.
Jan 10, 2011 | Hardware & Accessories
Hardware & Accessories Logo
43 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
