Question about Ricoh Office Equipment & Supplies
Ricoh copier MP c4501 Error Fusing rollers needs to be replaced now.
spinal
  • 287 Answers
SOURCE: ricoh aficio mp 2510
Hello e3tech, faatmaan has given you some valuable and accurate information. I would like to offer you some additional information that may help. i am not sure to what degree you have technical experience regarding problems as deep as you are experiencing. I just want to try to help you starting with the basics. We can get the proton accelerator out as a last resort. :-) In the event you have not tried to reset the code (which you can in the event that this code was a temporary condition or erroneous to start with) let me walk you thru the process of resetting the code and lets see if the copier can recover without going into the ugly (but prehaps necessary) and expensive stuff. Again I am just trying to help and this is the first thing anyone should do. We need to enter service mode, usually accessed by the expensive on site technician but you can handle it. This is the first thing I would do if I was onsite. I have been working on copiers for 20 years, which may merely mean I have been on a reign of terroe for that long, screwing everything up! LOL .Ok in order to enter sevice mode on your machine you will need to press the yellow button marked "clear modes" then then numbers 1-0-7 in slow but firm sequence, and the the orange stop clear button and hold IT down tull the screen changes and you will hear a beep. Once again......Clear modes,then 1>0>7 (in sequence) then hold down the orange stop/clear button till the screen changes and you hear a beep. (note....the beep is not guaranteed as it can be turen off prior to what we are doing but you will see the screen change). the new screen may say a number of things but for sure it will have a block named copier. Press that block which will bring up another new screen with all kinds of stuff that you need not be concerned with.The fact that you are at this screen is the cool thing. At this point, turn the main power swith off....!!!!!! THE ONE NEXT TO YOUR LEFT KNEE!!!!!! not the one on the op panel. Unplugging the copier will do the same if you are unsure.The point is to totally de-energize the copier. Turn the copier back on, and this point it will know that some one who knows what they are doing it attempting to help it recover andthe copier will wake up witha new outlook on life and will try to successfully restart back to normal. Without the steps we just went through the copier would have not went through the servicr mode process required foe it to truly have a chance to recover. When you turn it back on, the copier will look at all the critical sub systems it monitors before it feels comfortable to say "READY". In this case the errer code has to do with the very high temperature area called the fuser. As you probably understand, the manufacturer of the copier has designed the copier to keep close tabs on this area as to not burn down your building. So id there is any oddity in this area the machine throws a temper tantrum. So, lets hope hope the machine restarts, and it was a temporary thing , and you wont have to go the route that faatmaan suggested, which again may be absolutely accurate and well detailed. I just thought we could try the reset and hope for the best as it is a genuine and viable option and alot less expensive. I wish you the best. By the way, in the future, ALL error codes you get in the future(and there..are a hell of alot of them) can be reset in the manner I described ealier.This can be a big help for you . It just so happens that this and a few others in the "500" series are less likely to stay reset. I hope I have helped save you alarge wad of cash, but a minimum you are armed with a few valuable tools that may save you buttocks in the future. Take care.................. SPINAL
Posted on Feb 19, 2008
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
angelus316
  • 41 Answers
SOURCE: Ricoh Aficio MP 6000 copier with error code SC555
there is no sc 555 on those machines only sc 550 and that relates to what is called a fuser web.It does need to be changed but you can reset it by pressing the following in order
1- yellow clear key
2- number 1
3- number 0
4- number 7
5- press and hold down the orange clear/stop key for 5-10 seconds.
the screen changes
select copy sp
select sp 1
scroll down to SP1902 001 and select
reset that value to 0 and select enter
switch machine off and on and that should get you going for now.
Let me know
Posted on May 28, 2009
  • 398 Answers
SOURCE: purchased new fusing unit for ricoh cl3500n;
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Posted on Jul 08, 2009
Ricoh aficio mp 2045 sc 542
Description Fusing temperature warm-up error
The fusing temperature does not reach the fusing standby temperature of 45C (113F) within 9 seconds [for the B003/B006 (35 cpm)]/14 seconds [for the B004/B007 (45 cpm)] after switching on the main power or closing the front cover, or 40 seconds after reaching 50C the fusing roller does not reach warm-up temperature. Causes • Fusing lamp defective • Poor fusing unit connector • Thermistor warped or broken • Thermostat has tripped • BICU defective • Power supply board defective
Jan 04, 2015 | Ricoh Office Equipment & Supplies
Ricoh 430dn error sc565
Pressure roller fusing lamp consecutive full power 3
When the fusing unit is not running in the ready condition, the pressure
roller fusing lamp keeps ON full power for 30 seconds or more.
?? Broken pressure roller thermostat
?? Broken pressure roller fusing lamp
1. Replace the pressure roller fusing lamp.
2. Replace the pressure roller thermostat.
3. Replace the PSU.
May 19, 2014 | Ricoh SP C430DN Laser Printer
Error code sc542
Fusing Temperature Warming-up Error
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermofuse open
• BCU defective
• AC drive board defective
• Poor fusing unit connection
Jan 20, 2014 | Ricoh Aficio MP 161 Black and White Copier
How to reset a replace fusing belt unit error msg for ricoh mp c3502
Hi.
It needs to be replace the Fusing Belt or na expecifique Fuse (if the belt is still ok). Enyway you need to have knowledge and tecnical skils for do it. It is not a simple procedure ever for a high skill tec
Dec 28, 2013 | Ricoh Aficio CL3500N Laser Printer
Codigo sc 552 ricoh 3800
SC 552 - Pressure roller warm-up error
Definition: After the main switch is turned
on or the door is closed, the
pressure roller temperature
does not reach the ready
temperature within 150
seconds during fusing unit
warm-up.
Possible Cause:
• Pressure roller fusing lamp broken
• Defective pressure roller thermistor
• Defective BCU
Troubleshooting Procedure:
1. Check if the pressure roller thermistor
is firmly connected.
2. Replace the fusing unit.
3. Replace the BCU.
Mar 01, 2011 | Ricoh Aficio 3800CMF Laser Printer
Help me fix error code 551 on ricoh 4506 digital copier
551 A Pressure roller thermistor open
- Timing -Every 1 second after the fusing unit is installed
- Condition -The pressure roller thermistor output is almost close to 5V,which corresponds to 0
Sep 17, 2010 | Ricoh 4506 Copier
Code error SC 541 ricoh aficio mp2550
SC541 is a Fusing thermistor open (center) The temperature of the hot roller remained below 0oC for 5 sec at the center of the hot roller. Fusing thermistor out of its position because of incorrect installation. Fusing thermistor disconnected or defective power supply not within rated range (15% or more below rating). Try cleaning or replacing the thermistors and reset code in service mode.
Jan 30, 2010 | Ricoh Aficio 1035 Copier
Ricoh 3800c Error code sc555
SC 555 Pressure roller
fusing lamp
running in the Ready condition,
keeps ON with full power for
100 consecutive seconds.
Dec 01, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
times.
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
Nov 17, 2008 | Ricoh Aficio AP3800C Laser Printer
539 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
