Question about Ricoh Office Equipment & Supplies
Copier ricoh MP c4501 error message: fusing roller needs to be replaced now
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
spinal
  • 287 Answers
SOURCE: ricoh aficio mp 2510
Hello e3tech, faatmaan has given you some valuable and accurate information. I would like to offer you some additional information that may help. i am not sure to what degree you have technical experience regarding problems as deep as you are experiencing. I just want to try to help you starting with the basics. We can get the proton accelerator out as a last resort. :-) In the event you have not tried to reset the code (which you can in the event that this code was a temporary condition or erroneous to start with) let me walk you thru the process of resetting the code and lets see if the copier can recover without going into the ugly (but prehaps necessary) and expensive stuff. Again I am just trying to help and this is the first thing anyone should do. We need to enter service mode, usually accessed by the expensive on site technician but you can handle it. This is the first thing I would do if I was onsite. I have been working on copiers for 20 years, which may merely mean I have been on a reign of terroe for that long, screwing everything up! LOL .Ok in order to enter sevice mode on your machine you will need to press the yellow button marked "clear modes" then then numbers 1-0-7 in slow but firm sequence, and the the orange stop clear button and hold IT down tull the screen changes and you will hear a beep. Once again......Clear modes,then 1>0>7 (in sequence) then hold down the orange stop/clear button till the screen changes and you hear a beep. (note....the beep is not guaranteed as it can be turen off prior to what we are doing but you will see the screen change). the new screen may say a number of things but for sure it will have a block named copier. Press that block which will bring up another new screen with all kinds of stuff that you need not be concerned with.The fact that you are at this screen is the cool thing. At this point, turn the main power swith off....!!!!!! THE ONE NEXT TO YOUR LEFT KNEE!!!!!! not the one on the op panel. Unplugging the copier will do the same if you are unsure.The point is to totally de-energize the copier. Turn the copier back on, and this point it will know that some one who knows what they are doing it attempting to help it recover andthe copier will wake up witha new outlook on life and will try to successfully restart back to normal. Without the steps we just went through the copier would have not went through the servicr mode process required foe it to truly have a chance to recover. When you turn it back on, the copier will look at all the critical sub systems it monitors before it feels comfortable to say "READY". In this case the errer code has to do with the very high temperature area called the fuser. As you probably understand, the manufacturer of the copier has designed the copier to keep close tabs on this area as to not burn down your building. So id there is any oddity in this area the machine throws a temper tantrum. So, lets hope hope the machine restarts, and it was a temporary thing , and you wont have to go the route that faatmaan suggested, which again may be absolutely accurate and well detailed. I just thought we could try the reset and hope for the best as it is a genuine and viable option and alot less expensive. I wish you the best. By the way, in the future, ALL error codes you get in the future(and there..are a hell of alot of them) can be reset in the manner I described ealier.This can be a big help for you . It just so happens that this and a few others in the "500" series are less likely to stay reset. I hope I have helped save you alarge wad of cash, but a minimum you are armed with a few valuable tools that may save you buttocks in the future. Take care.................. SPINAL
Posted on Feb 19, 2008
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
angelus316
  • 41 Answers
SOURCE: Ricoh Aficio MP 6000 copier with error code SC555
there is no sc 555 on those machines only sc 550 and that relates to what is called a fuser web.It does need to be changed but you can reset it by pressing the following in order
1- yellow clear key
2- number 1
3- number 0
4- number 7
5- press and hold down the orange clear/stop key for 5-10 seconds.
the screen changes
select copy sp
select sp 1
scroll down to SP1902 001 and select
reset that value to 0 and select enter
switch machine off and on and that should get you going for now.
Let me know
Posted on May 28, 2009
Ickoajnc
  • 183 Answers
SOURCE: Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Posted on Jan 22, 2010
Minha Ricoh SPC 430DN deu erro SC 563, podem me ajudar. Sou do Rio de Janeiro - Brazil
  • Code: 563
  • Description: Pressure roller overheat 3 (software error)
    The detected fusing roller temperature stays at 230°C or more for 1 second.
  • Causes: • Defective PSU • Defective BCU
  • Remedy: 1. Replace the pressure roller thermistor (center). 2. Replace the PSU. 3. Replace the BCU.
Ricoh Aficio SPC430DN Error Codes List page 11 from 17
Esto dice que es posible que el Photo Conductor Unit Copier Drum es malo o el Color Copier BCU Engine Control Board es malo.
Jan 26, 2018 | Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
RICOH MP 2000 ERROR OCCURED SC302
That is a charge roller current leak. A current leak signal for
the charge roller is detected. Possible cause- charge roller damaged or high voltage supply board defective. Check the charge roller first. On the drum, the rubbery roller.
Jul 10, 2014 | Ricoh Aficio MP 1600L Black and White...
Functional problem sc 302 in ricoh photocopier model aticio1600
the charge roller in the drum unit is faulty or need to be cleaned.strip the drum unit and clean the unit
Sep 06, 2010 | Ricoh Aficio MP 1600 Black and White...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
206 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
