SOURCE: h350 bluetooth headset can't connect to laptop any solution
first insert the bluetooth devices in the usb port.second open your disk drive and install the software from the cd. Then press on " connect"
SOURCE: N95 - not recognising bluetooth headset
http://darlamack.blogs.com/NokiaN95usermanualUS.pdf
Here is the manual for your phone. Page 28 describes how to get your phone ready for your bluetooth headset.
But as for your headset, it depends on the individual headset. If you had a plantronics headset, you would go to their site, http://plantronics.com/ , click their support section, and then find your headset and grab the manual off the site for it.
Usually for headsets, it involves holding the power button on for so long, then entering your default password for the headset(usually 1111) into your phone.
Between your phones manual, and the headset one, you should be good to go. :)
SOURCE: connecting bluetooth headset
You have to go through a process to pair the devices.
Firstly:
Make sure bluetooth is turned on on your laptop (varies for each model)
Make sure the headset is fully charged.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Then goto the bluetooth control panel and select "Look for Devices" or similar. Wait until the device has been found and when it asks for a passkey, enter 0000 and press okay.
see some more info at: http://tinyurl.com/2bz7hc
SOURCE: bluetooth ps3
MASTER RESET
At front of the receiver there is a button. Press it down
for 2 seconds. Next on the controller, hold the left 2 shoulder buttons down
WHILE re-inserting battery. Press the SQUARE button. Your controller should be working as normal.
SOURCE: Iphone does not pair with LG HBS-250 Bluetooth Headset
the bluetooth of iphone is not compatible with this.get the bluetooth application installed from itunes store to maki it compatible.
