Question about Ricoh Office Equipment & Supplies
In ricoh 2510 copier while coping from ADF the copy is in reverse image. Copy in mirror form. Copy can read from back side of the paper. Please answer . Muhammad mazhar
I have replaced controller board.
  • 58 Answers
SOURCE: Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
diddydaveh
  • 154 Answers
SOURCE: slow copying
normally, it's because you are copying in a high resolution. have a look at your user manual, lower the scan resolution and it should be a lot faster. Check that you're scanning in black and white -that can speed things up as well.
Posted on Feb 12, 2009
  • 19 Answers
SOURCE: Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Posted on Jun 18, 2009
  • 17 Answers
SOURCE: The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Posted on Jul 07, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
My e studio 232 toshiba has a problem in back to back copy, everytme i use it the copy out adjust more or less one inch down please help me
if you are using the adf, try to check the timing of the rollers...your magnetic clutch might need some cleaning...the moving down or moving up of image is usually caused by missed timing in adf and paper...
May 24, 2014 | Toshiba e-STUDIO 282 Black and White...
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
When use adf with letter paper sise, push print botton then askme paper 5 1/2 X 8 1/2 inch´s, why do this?
is there any sensors on the adf unit, if so is the paper being feed into the adf unit, there might be a bad/defective sensor, try placing a letter size sheet on the document glass and make a copy, if it copies you have a problem with the adf, and it needs to be serviced
Feb 19, 2010 | Ricoh Aficio 2018D All-In-One Laser...
I have a ricoh spc232sf multifunction printer which is giving a error message of cannot copy and it says feeder adf what do i do?
the ADF is the upper cover where you put the document to be automatic feed by the machine, that is the part which you pull up when you want to copy on the exposure glass, on the left side of the ADF has a little door which you need to open. It is opened like a car door opener and pull it on the right side. see do have some paper inside if do not have paper close the door and lift the ADF in to up position and than set it back. with this you will rest the message.
Please answer do this is helpful for i to know do i should post some more information.
Regards
Jan 12, 2010 | Ricoh Aficio SPC232SF All-In-One Laser...
It senses paper loaded into the ADF but doesn't feed
There should be a button with settings on it.....ie: 2 sided, collate, etc. There should be an option to change paper settings.......or just clear the whole menu, and go to default to reset the rollers.
Oct 19, 2009 | Canon PC-980 Color Copier
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Top feeder not working MF6550
One or both of the ADF hinges are bad. The ADF cover doesn't close all of the way causing feed failure of the original and shading on the side of the copy because the scanned original is not fully contacting the **** exposure glass on the front operators side.
Feb 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Image wrap with adf
You have to reinitialize the software. I will be back in a few minutes with the procedure. I have to hunt it up.
Jan 23, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
