Question about Shakespeare Sport & Outdoor - Others
How do you replace a bail spring on a shakespeare spinning reel
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
  • 7 Answers
SOURCE: I have a shakespeare sigma fishing reel that
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
Posted on May 21, 2009
  • 10 Answers
SOURCE: Shakespeare fishing reel schematics
try online at www.reelschematics.com they should be able to give you help.regards barry.
Posted on Sep 29, 2009
  • 17 Answers
SOURCE: I have a shakespear alpha fishing reel which
The switch is the on/off anti reverse switch. It is the switch (probably the only one) on the reel at the base. When the reel is in the upright position, look at the bottom/rear area. That little level controls the reverse. Good fishing...
Posted on Nov 16, 2009
Testimonial: "Hi Thanks "
SOURCE: My Shakespeare SKP 2000C won't reel in.
you may need to tighten or fix your drag.
Posted on Nov 26, 2009
Where can i get manual for assembling cardinal models10 fishing reel
do you till have the box it came in.many reel companies printed the diagrams on the inside .
Mar 28, 2015 | Abu Garcia Cardinal S Spinning Reel, Reel...
My line won't rewind on my Shakespeare Encore reel. After casting, the bail snaps in place, but when I reel in, the line won't reel in. The spool turns with the bail, but doesn't retriev
Your line is on the wrong side of the bail. Rethread the line so its over the bail so that after the cast you flip it up it catches the line and retracts it.
May 05, 2012 | Sport & Outdoor - Others
Does not flip arm to lock to reel in line
Normally when you **** the bail, the reel allows you to discharge the line with a flip of the wrist. Then when you touch the crank and execute half a turn it releases the bail to lock the line and allow you to reel in. If this action is not happening, then the release pawl is stuck and holding the bail in place. You must disassemble the reel, clean the parts and re-assemble with proper lubrication. Checking the parts for wear replace all worn parts.
Jun 22, 2011 | Shakespeare Agility Spinning Reel 6825
I have a Shakespear Tiger model TSP50A. I cannot set the on/off so that the handle ends up going both ways. I inspected the gears and suspect a manufacturing defect. I have had it for over 3 years but used...
Remove the spool, you'll find a little screw by a hex nut, remove the little screw then you can remove the hex nut. by removing this nut you will be able to remove the whole bail assembly. There you'll find the workings of the on/off leaver. There is a fine spring that raps around a brass piece that looks like a washer, looking at it from the side you'll see a grove in it, that is where the spring goes then to the leaver of the on/off control. This spring hardly has any spring to it so don't think it needs a replacement. If the spring is in place check to be sure that the knob isn't striped. Just take the little screw off that holds it in place and inspect it. I hope this helps!
Jun 17, 2010 | Shakespeare Agility Spinning Reels
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Need to know were the long spring on my sons spider man rod and reel goes
The long spring (only one in the reel) goes under the bail arm plate. To get it back in, remove the plastic cover plate on the side that pickes up the line (has a line roller on that side). The spring will fit over a small metal or plastic post and rest in a cavity at the bottom.
Screw the cover back on and you're good to go!
Best of luck
Mike
Sep 26, 2009 | Shakespeare Surf Fishing Rod and Reel...
How do you cast?
flip the bail(the round rod in front of the reel)hold the line tight with your finger first and cast(make sure you let your finger off the line when you throw the rod forward.
Jul 17, 2009 | Shakespeare Agility Spinning Reel 6825
Sport & Outdoor - Others Logo
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
