Question about Consew Sewing Machines
My 225 consew won't pick up the bobbin - Consew Sewing Machines
  • 323 Answers
SOURCE: Threading & bobbin won't pick up
Make sure the needle is inserted all the way in with the long groove to the left.
Threading is through 1)the thread guide 2)The tension 3)The take up lever 4) The needle eye (left to right).
Remove the needle plate, thread the machine. Turn the hand wheel and watch the thread in the needle to see if it is above the eye of the needle. If it is, the machine needs to be retimed.
Sewman7
Posted on May 14, 2008
SOURCE: The machine won pick up the bobbin thread, it jams when starting
wont pick up thread from bobbin
Posted on Nov 28, 2009
  • 6 Answers
SOURCE: I have a consew machine 226 and the needle thread
your needle is in backward, the groove must point to the left.
Posted on Jan 27, 2010
  • 4 Answers
SOURCE: tension problem, consew 225
I would go out and get a new bobbin case if i were you. I bet that screw is stripped out
Posted on Aug 06, 2010
  • 255 Answers
SOURCE: My husband purchased an old model Consew machine.
Check your manual to see which way the flat side of the needle shank should face. With modern machines, it's usually to the rear, away from you, but with older machines there was more variation.
The most common reason the needle won't pick up the bobbin thread is because the flat side of the needle is facing the wrong way for that machine.
Hope this helps!
Robbie
Posted on Aug 10, 2010
My consew model 225 just had a new belt and oiled was sewing this morning and last night leather but will not pick up the bobbin thread just poking holes into the leather. Please help
Check bobbin threading and tension. Make sure correct needle is installed and threaded right. Belt and oil have zero to do with the problem.
Jun 28, 2014 | Consew Sewing Machines
I have a consew 225 I think and when I try to bring the thread up from the bobbin the thread from the needle goes down and around the bobbin to bring up the bobbin thread and catches. It will not pass
Your machine probably needs to be adjusted and timed. But make sure you clean under the bobbin area before you try again... or take it to a machine pro
Jul 18, 2012 | Consew 226R-1
My husband purchased an old model Consew machine. It is mounted on a table and came with the instruction manual for models 225 & 226R-1. The machine will NOT pick up the bobbin thread. Any ideas?
Hope this helps!
Robbie
Aug 07, 2010 | Consew 226R-1
Thread stuck around the bobbin housing on my
try cleaning all that you can out of the bobbin case then try very carefully to bump it backward (opposite) with the hand wheel . Be careful not to knot out of timing. sounds like you have thread in between bobbin case and hook
Apr 06, 2010 | Consew 339RB-3 Sewing Machine
Tension problem, consew 225
The bobbin should have a thin metal peice that the thread goes under to create tension, the screw closes to end the thread comes out of is the one to adjust. If they were sewing with a light thread on the machine the tension on the bobbin is probably set pretty tight loosen it a little at a time, turning the screw counter clockwise. You might need to check your top tension also if it is showing a knot on the bottom. The bottom is to tight or the top is to loose.
Nov 03, 2009 | Consew 226R-1
Looking for instruction to use the bobbin threader on a consew 206rb-2
Contact this company as they make Consew and will have exactly what you need.
WESTCHESTER SEWING MACHINE CO.
Phone; 800-225-8342 / 845- 627-8873
May 04, 2009 | Sewing Machines
Consew 226 r sewing machine
do you have the user manual?
Sep 15, 2008 | Consew 206RB
Sewing Machines Logo
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
