Question about HP Garden
How do I add transmission oil to rear end on a ariens 17.5 hp 42 cut
bargainbin2
  • 123 Answers
SOURCE: my murray 17 hp 42 inch cut hydrostat mower will
Hydrostat transaxles are very picky like the trans in your car. It must have clean fluid and be full of fluid. I am not saying to fill that transaxle to the top but make sure it is to the top of the fill line. Also it needs to be changed every few years and keep it clean to help it stay cool. If it has a filter make sure to change it when you change the fluid in the transaxle. That fluid is nothing more than 20-50W motor oil.
Posted on Sep 01, 2009
  • 491 Answers
SOURCE: 17 hp rider mower 42 inch cut. willnot move in any
Is the belt in place which drives the transmission?
The belt should run from a pulley on the engine to a pulley on the transmission....if you have a belt drive system (the most common).
Posted on Oct 18, 2009
huffman49
  • 235 Answers
SOURCE: We need the electrical diagram for a 17 HP
this is as close as i can find.. take a look and see if you can use this diagram...good luck. go to page numbers 34 and 35
http://www.hammerwall.com/Download_Manual/18200/
Posted on Apr 12, 2010
emissionwiz
  • 80531 Answers
SOURCE: diagram for 1987 rear end monte carlo how to add
there is a recessed fill plug on the nose of the diff housing (faces front)
Posted on Aug 21, 2010
  • 2239 Answers
SOURCE: I GOT A SEARS CRAFTMAN riding lawnmower 17 hp 42 inch cut kohler engine.and when i start oil come out of my exhaust what causes that
Either over filled with oil, valve stem seals leaking, engine breather blocked, or the engine is badly worn.
Posted on Mar 13, 2012
How do I adjust the carburetor on an Ariens 5020 tiller, model #901016, with a 5 HP Tecumseh engine?
close the needle valve completely, then back it off 1.5 turns. Adjust from there for most efficient fuel usage.
May 04, 2015 | Ariens Rear Tine Tiller 17 901028
Does arien mower have a hydrostatic transmisson?
Some units do have hydrostatic transmissions, but most of the 42" units have 6 speed geared transmissions. To be absolute, you will need the product number.
Jun 16, 2014 | Ariens 42" Riding Lawn Mower Blade ...
How to add oil to rear end
most likely it is a sealed unit so you will not be able to check, add or replace fluid.
May 04, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to change the oil
at the base of the dip stick tube there is a quarter turn black nipple push it in and turn it you can add a hose to the end to help it drain into a pan without the mess
Sep 24, 2012 | Ariens Zoom XL 54 In 24 HP Kawasaki Zero...
I have a Craftsman 17.5 hp 42 in.cut riding lawn mower that I've had for about 5 years now, and the rear end is starting to make a whinning sound..How do I grease, or oil the rear end?
It a sealed unit. No service needed. They said call service provider. You tear it apart, if you want. Remove axle from mower. The case unbolt in two pieces>
May 08, 2012 | Craftsman Garden
Mar 13, 2012 | Garden
The transmission on my ariens automatic 19 hp stopped working, what can i do to fix it?
Check the drive belt first, it will be the upper belt. you will need to make sure a stick or something hasnt jammed up there and knocked it off. It will be easier to remove the mower deck so that you can get under the tractor to look up and check it out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 03, 2010 | Ariens 42" Riding Lawn Mower Blade ...
17 hp 42'' rider with hydrostat with hand controls wont move.... mis their oil in the rearend?????? or what else could it be,the belt is on
mowre will start but will not go into gear shaft will turn but not engage how can i get to trany without complete breakdown of *** end
Jun 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I am trying to get my 18.5hp 42" cut craftsman DLT3000 to move. The rod in the back is in, and the wheels are still locked up on the transmission. What would cause the transmission to lock up?
At the end of the rod under the battery there is a lever that bolts to the transmission you will need to spray with wd40 and tap it with a hammer back and forth until it starts to move then continue to oil it and move it back & forth with your hand , its stuck in the gear position. if you are looking to get it in the neutral position follow the above procedure these catch alot of dirt and seize up.
May 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
17 hp rider mower 42 inch cut. willnot move in any gear or reverse. how does this transmission work?
it uses the belt as a clutch so that would be the first thing to check
Oct 18, 2009 | Garden
Garden Logo
Top HP Garden Experts
Vernon Taylor
michael vanier
Are you a HP Garden Expert? Answer questions, earn points and help others
