Question about HP Garden
I have a 17.5 hp 42" cut, how do I add oil to transmission
bargainbin2
  • 123 Answers
SOURCE: my murray 17 hp 42 inch cut hydrostat mower will
Hydrostat transaxles are very picky like the trans in your car. It must have clean fluid and be full of fluid. I am not saying to fill that transaxle to the top but make sure it is to the top of the fill line. Also it needs to be changed every few years and keep it clean to help it stay cool. If it has a filter make sure to change it when you change the fluid in the transaxle. That fluid is nothing more than 20-50W motor oil.
Posted on Sep 01, 2009
  • 474 Answers
SOURCE: 15.5/42 manual & oil filter
may not have a filter.try briggsand sratton.com. you will need all the info off the data plate on the engine
Posted on Sep 14, 2009
  • 491 Answers
SOURCE: 17 hp rider mower 42 inch cut. willnot move in any
Is the belt in place which drives the transmission?
The belt should run from a pulley on the engine to a pulley on the transmission....if you have a belt drive system (the most common).
Posted on Oct 18, 2009
huffman49
  • 235 Answers
SOURCE: We need the electrical diagram for a 17 HP
this is as close as i can find.. take a look and see if you can use this diagram...good luck. go to page numbers 34 and 35
http://www.hammerwall.com/Download_Manual/18200/
Posted on Apr 12, 2010
SOURCE: 17 hp 42'' rider with hydrostat with hand controls
mowre will start but will not go into gear shaft will turn but not engage how can i get to trany without complete breakdown of *** end
Posted on Jun 28, 2010
Murray 42 in 17 hp doesnt start
i would look at the safety switches that being the most common cause
Jun 16, 2012 | Garden
I have a Craftsman 17.5 hp 42 in.cut riding lawn mower that I've had for about 5 years now, and the rear end is starting to make a whinning sound..How do I grease, or oil the rear end?
It a sealed unit. No service needed. They said call service provider. You tear it apart, if you want. Remove axle from mower. The case unbolt in two pieces>
May 08, 2012 | Craftsman Garden
I GOT A SEARS CRAFTMAN riding lawnmower 17 hp 42 inch cut kohler engine.and when i start oil come out of my exhaust what causes that
Either over filled with oil, valve stem seals leaking, engine breather blocked, or the engine is badly worn.
Mar 13, 2012 | Garden
Poulan Pro 300 42" cut
Likely a valve or check valve is frozen. Refer to your manual showing hydraulic circuits and it will probably be obvious where a blockage that prevents ANY oil flow to the drive motors could occur.
Jun 30, 2011 | Garden
I am trying to get my 18.5hp 42" cut craftsman DLT3000 to move. The rod in the back is in, and the wheels are still locked up on the transmission. What would cause the transmission to lock up?
At the end of the rod under the battery there is a lever that bolts to the transmission you will need to spray with wd40 and tap it with a hammer back and forth until it starts to move then continue to oil it and move it back & forth with your hand , its stuck in the gear position. if you are looking to get it in the neutral position follow the above procedure these catch alot of dirt and seize up.
May 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
We need the electrical diagram for a 17 HP Craftsman 42" cut riding mower. Model-311707 Type-0321-E1
Apr 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman Riding mower 17 HP, 42"cut. It runs for ~30 minutes then shuts off like it's out of gas, but it's not. Won't restart for ~30 min. Can anyone help
check for fire to the plug after it dies....if there is no fire then its possible that the coil is breaking down and needs to be replaced.
Nov 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
17 hp rider mower 42 inch cut. willnot move in any gear or reverse. how does this transmission work?
it uses the belt as a clutch so that would be the first thing to check
Oct 18, 2009 | Garden
I have a 42 inch craftmas mower and the fluid is leaking from the hydrastatic area, can I replace it with transmission fluid.
If you transaxle is leaking badly adding oil may not help long term,if you remove the back hitch plate there is a allen wrench plug or a rubber vent hose, you can add oil there,measure down from the top of transaxle and fill to within 1.5 inch of the top,always allow 1.5 in of air space in top to allow for expansion. Add amsoil or mobil 1 synthetic motor oil 15w-50 or 20w-50. Do not use transmission fluid or hydraulic oil.
Jul 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need to know how to put gear oil in a 95 jetta.if you have pictures how to do that.
Jack up the car on the driver side. Then you need to take off the Driver side Tire. You will see a 17 hex Allen socket on the transmission; this is where the gear oil goes. On the bottom of the transmission is another 17 hex socket: this is how you drain the transmission fluid. The car takes (75w90 GL-4). I believe the capacity is about 2.0 quarts. But put in about 1.5 quarts first, to see how the car feels, and then add more later.
Mar 28, 2009 | 1995 Volkswagen Jetta
Garden Logo
22 people viewed this question
Top HP Garden Experts
Vernon Taylor
michael vanier
Are you a HP Garden Expert? Answer questions, earn points and help others
