Question about Element Televison & Video
Element elefw408 not powering up do you think its the main board
Red indicator on front not illuminated either tried different outlets in home no change . checked main power board seems to not be getting dc voltage to some areas that should have it do you think i need a new main board
  • Element Master
  • 10,045 Answers
TV Parts Universal TV Stands DLP Chips ShopJimmy If there are DC voltages no longer present on the power supply board, these guys can either repair your board or supply you with a new one.
Posted on May 05, 2017
  • chance westbrook
    chance westbrook May 05, 2017
    that's what I figured they have one in stock just wanted to make sure that's what I needed before ordering it lol thanks for the help
Does my tv support wireless display/miracast? It is an Element 40" model # ELEFW408
It is an entry level television, so no. One review states this;
Element ELEFW408 specs - This model comes with an LED panel size of 40 inches and a resolution of 1920 x 1080 and an aspect ratio of 16:9, a contract ratio of 4,000:1 and a brightness level of 200cd/m2. This is a Full HD 1080p TV with a refresh rate of 60Hz, so not ideal for some of the faster paced sports games. The ELEFW408 comes with a built-in tuner, 3 HDMI ports, although from the look of it lacks wireless connectivity, but with no Smart TV functions this was to be expected.
Element ELEFW408 TV specs with review indecision
Jan 19, 2016 | Tablets & eReaders
Fix back light inverter on my 40" ELEMENT led flatscreen tv. Model ELEFW408
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 06, 2016 | Element Electronics Televison & Video
I have a 32 inch Samsung TV that is only two years old. When you press the power button, it sounds like it it turning on and the red light comes on but the screen is black and there is no sound.
Main board is bad since it works with both video and audio. Ur backlights are ok so that omits the inverter board. And the T con board is for video only - since you have hassles with audio and video that leaves the main board. Do not think it is the power supply since your inverter board is powering up the back lights.
Nov 11, 2015 | Samsung UN39FH5000FXZA - 39in 1080p 240...
Lexmark 3300 printer wont turn on
Is this a personal (home) or business printer? Eitherway, I would check your warranties to see if your printer is covered. If the printer is not receiving power, try a different outlet. If you have done this already and a "red" indicator is flashing, then it might be time to make a repair call. Check the prices between purchasing a new printer or repairing the old one before you make any decisions. Good luck.
Jan 02, 2015 | Lexmark Office Equipment & Supplies
Samsung UN46D7000 red light blinking and clicking
I have this exact same model "UN46D7000LFXZA" with the exact same problem and I also replaced the power board expecting that since that is where the clicking was coming from that would fix it even though there were no swollen capaciters. However, it didn't and the board is from a working pull so I knew that was not the issue. What I did is I unhooked the main board connection from the power board and turned it on to test a hunch, and instantly the LEDs powered on and no more clicking. I just received a main board in the mail switched it out a few minutes ago to confirm it was indeed a main board problem. I got mine for $114.99 on eBay after confirming that the part numbers that were slightly different were interchangable. I lost all of the firmware upgrades changing out the main board obviously but downloading and installing those is a small price to pay for finally having a working 3D TV back for less than the cost of the extended warranty.
I would suggest carefully trying the same thing and disconnecting your main board and make sure your LEDs light up. I bet they will. I was just guessing at the main board but since there are only two boards left after the power board was replaced and the other board should have no affect on the power board to my knowledge I think this will fix your issue too.
Apr 14, 2012 | Televison & Video
My la cornue oven not heating, turn 1st knob to function desired and then temperature knob to desired temp but oven does not heat up
First thing should be to make sure the top selector switch is not set to the optional Pizza element.
Make sure the power to the unit is OFF. Also keep in mind that the following tests should be done by a qualified appliance specialist. To find one near you, contact the La Cornue Service Center @ 877-522-6768
Is this the first time using the oven? If so, make sure the overall power to the range is 240 volts. This can be checked at the main terminal block.
If your model has three indicator lights and the red light is illuminated, then it is likely the hi-limit thermostat has tripped and you will need to reset it. The reset switch is located underneath the cycling thermostat. To access this, you will need to remove the front fascia. Please note: The original safety thermostat is no longer available. Use current safety thermostat (reference: 06ELTS01). If your model has only two indicator lights and the red light is illuminated, that means the oven is heating up. If the red light is not illuminated when the thermostat is set at the desired temperature, then check the hi-limit thermostat.
Power relay/contactor on the back of the unit should be checked. It
Jan 06, 2011 | La Cornue Grand Maman Dual Fuel (Electric...
I have a Bunn/TF DBC that we keep having boards and heating elements going out on them (we have placed 3 different Machines)...I have had electricians telling me that the building power is fine and the it...
If the electricians are saying that the lines are and that there are no brownouts, then I would open the front panel on the machine and check that the terminals wires are correct, then the plug, then the outlet(I have been to places where the ground and neutral have been swapped at the outlet). If all that is correct, use your voltmeter to check incoming power between the red and black wires for 220 and the red and white, and black and white for 110. For so many heating elements and boards to go out, tells me that either the machine is running out of water, and the elements are overheating but the hi-limit reset switch should have caught it in time to save element. If you still have the old boards I would check them to see which part burnt out then you can have an idea if it is a power thing or water or solenoid or level control.
Sep 16, 2010 | Bunn Dual TF DBC Coffee Maker
TV won't come on using romote or controls on side of TV. Should there be a light on permanently on the front of the TV, because there isn't.
Yes, there'e usually a standby indicator LED that will illuminate when the TV is plugged in and not yet turned on. Flat panel TV's like these are notorious for bad power supplies and sometimes bad main boards. Try unplugging everything and maybe try a different outlet, or use something like a lamp to plug into the TV's current outlet (to verify power to the outlet). Might be time to call a shop however.
Jun 08, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Wii fit board won't work
Here you have different procedures on what to do if you get that error message. Please get back to me if nothing works.
The exact procedure is:
• Even if the battery level is strong, try the following:
Remove the batteries in the Wii Fit Board for at least 1 minute…… better 15
Try these steps!
1 Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
2 Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
3 After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
a With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
b Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
d When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
4 Start the game from the Wii Menu, then sync the Wii Balance Board from the opening screen of the game.
Hope it helped.
Nov 24, 2009 | Nintendo Wii Fit - Balance Board + Game...
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
Televison & Video Logo
50 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
