Problem with remote control LP70 laser not working after replaced batteries
Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Nov 17, 2007 | Onkyo TX-DS575 Receiver
My proscan remote doesn't work, and the batteries are good.'
If the batteries are good and are inserted correctly. Check the laser bulb at the top end to make sure it is clean and the receiver bulb on the TV to make sure it is clean and not blocked. If that still doesn't work then something in the remote has burned out or gotten damaged and is unlikely repairable.
Sep 28, 2014 | Samsung TV Remote Control
The laser will not light up. i've replaced the batteries
First, be sure to clean the battery connection points with an electrical contact cleaner and be sure that the batteries are new, not just different. If that does not work, try placing the instrument in a freezer for at least 30 minutes. This worked with my 5 point Stanley Fat Max. The freezer will cause some condensation to form on the inside of the instrument, but why it makes the diode work is a mystery, at least to me.
Sep 13, 2011 | Robotoolz RT-7210-1G Robolaser,...
My sharp aquos lc-42d65u is not responding to my remote control . another word my t.v does not read my remote control at all. can someone help me to fix my remote ?
U already change the remote control for brand new batteries wright?Yes.Remote controls devices are heavily depend on it CPU chip for all of it functions.Test the tv manual buttons like Power,Menu,Volume - + and Channel + - all work?Yes.The tv remote control CPU is dead that why doesn't read the tv infered laser signal at all.Try website like Remotes.com to buy an original remote for the replacement.
Apr 04, 2011 | Sharp LC42D65U 42 in. LCD HDTV
I have a RoboToolz RB01001 rotary laser. The green light comes on for approximately 2 sec. then goes out and the unit does not function at all. It has very little usage and has been cared for, never tossed...
That's usually a battery problem either in the laser unit or the remote control. The battery in the remote tends to disconnect if bumped. A small piece of foam pad at the bottom of the battery can fix that.
Jul 11, 2010 | Robotoolz RT-7210-1G Self-Leveling,...
Need robolaser instructions; can not get it to turn on. it has new batteries.I really don't know anything about this laser. It was my Dad's he has passed away.
Did u open the front and turn on the remote to activate the laser ? the model i have ( 8years old )this is what it takes to get the laser work.
Jan 10, 2010 | Robotoolz RT-7210-1G Robolaser,...
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
Remote wont work
for some reason unknown, the laser or infrared diode has died
May 20, 2007 | RCA 257003 Remote Control
Open Questions:
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
