Question about Dryers
My fan goes on with the remote but my light wouldnt go on its brand new. it worked for three days now wouldnt go on
4 Suggested Answers
  • 1779 Answers
SOURCE: Vizio 47" remote
If your manual buttons on the set do not work, then I would return the set. If they do work then contact the store on where to get a warranty replacement remote, or just go back to the store with the remote and see if it works on another Vizio.
Posted on Jun 18, 2009
SOURCE: Hampton bay fans
i have a hampton bay fan with a romote.out of no where the light turns on .no one is using anything .alot of times it happens at night when we are sleeping.i wake up to the light being on.what can i do to fix this problem?
Posted on May 10, 2010
  • 3368 Answers
SOURCE: My gazebo plus fan works but neither the lights nor the remote control are working. I ordered a brand new remote control but it doesn't work either so it's not the batteries. Any suggestions?
It sounds like it is the receiver which is part of the fan. If that does not resolve it repost with make and model numbers.
Posted on Dec 06, 2014
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Mar 14, 2008 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Remote control ceiling fan
Possibly a bad circuit board in the ceiling fans remote function. I would suspect that the circuit board has a thermal issue where once warm it works fine. The most common fault that I have seen is a bad solder connection on the board. Pull the board from the fan and check all solder connections for cracks or dull solder. If you see any of these then reflow the solder connections. If this does not work you probably will need to order a new board from the manu.
Jan 26, 2008 | Dryers
Remote control
Is the power led still lights on when you press any button of your remote pad? If not, maybe there's a loose connection of parts inside it.
Mon =)
Nov 14, 2007 | Hunter "Lexus" Traditional 52" Ceiling Fan...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Remote calibration
I installed three fans in the same room and one remote ran all three. In order to get the dimmers all to bring the lights up and down together, I changed the dip-switches in the fan housing so that the remote would only work one fan at a time. I then brought the dimmer lights all the way to bright. After all the lights were equally bright, I again altered the dip-switches so that all three and the remote were identical. The remote then dimmed all three lights equally.
Jun 16, 2007 | Hampton Bay AC438-VPW 52'' Vintage Pewter...
Fan wont work
I have the same problem, warranty on this fan is only 90 days...
Apr 25, 2007 | Sharper Image Deluxe Spire SI788SNX Tower...
Dryers Logo
Top Dryers Experts
