Question about Garden
Hit something now my pto will not ingage - Garden
    Top Expert:
  • Garden Master
  • 14,306 Answers
Check deck for damage
Posted on May 05, 2017
Craftmen gt 5000 pto will not ingage
need to check the deck --bent or damaged--blades,mandrel,pulley,pto cable,tentioner and belt pop
May 05, 2017 | Cars & Trucks
Pto will not work on ss4235
could be the switch, pto assy, fuse, broken wire. belt off the pulley. take your pick
Jun 18, 2015 | Toro Mowers - Time Cutter SS4235 42""...
Ive got a john deere 4055. Has a new clutch and pto release bearings and piston. The pto will not ingage and there is no pto pressure.
did the mechanic that installed the new parts pre prime the hydraulic pump on install , ive had limited luck using another tractors pump on remote circuit to back feed on the return line to "externally) prime the pump , but it has worked a few times , worth a try if you have the means
Mar 28, 2015 | John Deere Garden
HUSQVARNA Z4824 O TURN MOWER - NOCKS WHAN PTO IS INGAGED & STALLS
need throttle adjustment govenor adjustment possiblt new pto clutch you have to take in to shop adjustmets 50.00 pto clutch 200.00
Sep 03, 2014 | Garden
Husqvarns z4840 - nocks when pto is ingaged
check your blade spindles and pulleys and bearings. Also inspect the electric clutch.
Sep 03, 2014 | Husqvarna Decal, Z4824 Rh - HVP 539 11 27...
How can i get pto cluch to ingage?
This problem needs more information provided.
Look for safety interlocks that have not been engaged, or possibly broken. The switch under the seat will not allow the PTO to engage if it does not detect someone in the seat.
If the PTO is electric, look to see if the plug is loose at the PTO.
Check to make sure that the PTO mounting bolts are still secure.
May 20, 2014 | John Deere Garden
Blades won't stay ingaged
bad pto clucth overheating shutting off
Apr 07, 2013 | Cub Cadet Lawn Mower Electric PTO Clutch...
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
My pto will not ingage
most of the time its linkage adjustment or cable.Its been my experiance that if you let out lightly on the clutch moveing a little bit forward or reverse while ingageing the PTO that they go in smoother and completely
Sep 06, 2009 | 2000 Ferrari Enzo
Blades ingages and then stops
It sounds like the electric pto clutch is bad. If you are looking to get a new one try www.psep.biz scroll down to bottom and click on buy oem parts. Also check www.jackssmallengines.com. I can't remember which one was cheaper. Also try doing a search you might find a cheaper site.
Good luck let me know if this helps.
roundo4
Aug 13, 2009 | Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
