Question about Grilling
I have a error that says e4 on my electric smoker
My Deni electric pressure cooker is showing E4? Cannot cook?
An E4 Error for your Deni means that there is a signal switch error. Turn off the pressure cooker, un-plug, and wait for it to cool. Then, try again. If it continues to give you the E4 error I would recommend contacting the manufacturer - but, unfortunately, Deni has gone out of out business.
Here is the manual for your pressure coker, if you don't already have it:
http://www.hippressurecooking.com/category/manuals/deni/
Mar 18, 2016 | Kitchen Appliances - Others
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
Masterbuilt smoker error message EA2
EAA2 means connection to the meat probe is lost. Either a broken, burnt wire or the probe itself. Check the probe wire carefully to spot a break.
Jul 05, 2014 | Masterbuilt 20070411 30" Electric Smoker...
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
Dec 13, 2013 | Simmons Beautyrest Microfleece Electric...
Control says E4 and is not cooling
E4" on display for lower zone - error of DC electric fan for lower zone.
If any of above errors happens, please contact Customer Service Dept. for further assistance. Do not attempt to repair it yourself.
For Service or Assistance please call 888 775- 0202. Or visit us on the web at www.mcappliance.com to request warranty service. Your unit has a one year warranty from date of purchase. Hope this helps you. Jim
Feb 12, 2011 | Magic Chef MCWC44DZ Wine Cooler
I am getting a EEAF fault code and the smoker will not heat. What is wrong?
To RESET control panel:
If control panel shows an error message, turn electric smoker off, unplug unit from outlet, wait
ten seconds, plug unit back into outlet, then turn electric smoker on. This will reset control panel.
ASSEMBLY, CARE & USE MANUAL
WARNING & SAFETY INFORMATION
MODELS 20070106, 20070206
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
Replace the sensor as shown in the F6 code
F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
Error Code: E4
Cause: Shorted sensor
Example: Disables cooking in affected oven
Corrective Action: Check sensor
Nov 02, 2010 | KitchenAid KESC300 Electric Kitchen Range
EAAF Error Code
I went to start my smoker Thanksgiving morning in Denver and I got the EAAF error. I checked all electrical connections and they appeared fine; I next removed the digital control box and stuck it inside my jacket to warm it up (was 15 deg outside) and lit a candle inside the smoker. After 20 min I put everything back together and it worked. Just remember to remove the candle inside the smoker. I plan to call Mastercraft on Monday to see if they can tell me what EAAF means.
Dec 13, 2009 | Masterbuilt 20070106 Electric Smoker
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
Grilling Logo
122 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
