Question about Health & Beauty
Golden will go in reverse but only at a lessened speed and will not go forward at any speed. Just clicking noise when push on throttle.
    New Friend:
  • 23 Answers
What are you talking about? What or Who is Golden? Is it a real person needing health advice, or it a product? Please let me know what it or He, she, it is so that someone can understand what you need. Good luck till we get the answer that we need to help you. You always need to be specific with The Title of the Product, The Model, The Age, Where you bought it, and who owned it, and for how long they owned it. All of these points are very important in order to be able to help you. Good Luck.
Posted on May 07, 2017
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
  • 13 Answers
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Posted on Jun 18, 2009
  • 177 Answers
SOURCE: new battery. hooked up correctly. But, scooter
Hi. Did the machine used to operate properly in the past? Sometimes previous owners or technicians have changed the programme for owners for different uses. What you describe sounds like a faulty throttle pot ( Wig Wag ). I have changed many throttle pots for this reason.
Also check battery and motor connectors.
Do you have another switch on the machine for controlling the speed, such as an indoor/outdoor switch? Good luck. Neil.
Posted on May 29, 2010
  • 46 Answers
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Posted on Jul 11, 2010
SOURCE: I have 5 forward and 3 reverse speeds. My motor
Same problem. Bought motor used. Can't figure it out.
Posted on Jul 17, 2010
Can I change it from a right hand throttle to a Left hand throttle?
Is it a twist throttle on the end of the handlebars or a thumb bar?
if it's a twist throttle on the end of a handlebar.....no, because the throttle will have to twist away from you if you put it on the left, so it's totally not practical. If it's a thumb bar, a general rewire of speed potentiometer behind the push bar for forward and reverse will change throttle over to the left push and reverse over to the right push.
Jan 13, 2016 | Health & Beauty
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
It sounds to me like someone has gotten inside & tampered with it, Cameron. Maybe they twisted the drive belt 180 degrees or something? Or rewired the motor backwards?
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
I have a Golden Companion II, all power comes on:light, battery meter and horn but it won't move when I press the throttle. I do hear the click from the brake but it won't move forward or reverse. If its...
Tony Check the freewheel lever Make sure that the scooter can't be pushed easily. If you can push it then its in freewheel. Now Tony you could have a problem with the brake itself. There is a small micro switch on the brake that engages and disengages when you move the freewheel lever. If you can get a close look at it make sure that it still looks like its operating its a mechanical mech activated by the lever on the brake. If it looks ok and you can get the scooter in or out of freewheeling (the rear wheels lock and unlock) then it could be a throttle pot problem or a speed control pot problem. Fortunately you can't bypass the throttle or speed pot. You will have to get these checked by a tech either with your provider or a service company that has techs around your area. I'm sorry I couldn't give you a quick fix but scooters are more difficult to troubleshoot because of all the different componets necessary to make it go. Good Luck Hope this helps
Oct 27, 2010 | Golden Technologies Companion II Travel...
I need to find out how to adjust my shifting linkage for a 1988 mercury mariner 60 hp. i don't have a diagram
Its not too bad to adjust, just takes patience and an assistant would be nice. You want to center the linkage in neutral so the throttle does not move immediately when you shift.
This can be adjusted with the motor off. You need to try it first by putting the Handshift in neutral and spinning the prop by hand. The prop should spin without locking into gear or making a "ticking noise" with the gears partially meshing. If there is a "ticking noise" you need to disconnect the shift cable; adjust it until the noise is gone. Then reattach it.
Now have your assistant move the Hand Throttle slightly forward, the gears should make a "ticking sound" before the throttle cable moves, and the gears should lock into forward before the throttle cable moves. If the Throttle cable moves too soon, you want to disconnect the Throttle cable and turn the knurled fitting to return the Throttle cable to a closed position. Easy does it with these adjustments.
If you go too far while adjusting the Forward gear it can show up on Reverse. But remember, you do not need much Throttle in the Reverse gear. Reverse is only for manuvering at slow speeds. You want low RPM for Trolling in Forward so you want a little slack in the Throttle in Forward gear.
Jul 17, 2010 | Boating
New battery. hooked up correctly. But, scooter will still barely go in reverse super slow. forward speed slow .can throttle cable be problem/ when I push inside of speed lever it moves faster. pushing ends...
May 12, 2010 | Activeforever Lynx L4 Portable Mobility 4...
Golden companion 2 scooter moves slow in reverse
Mar 23, 2009 | Golden Technologies Companion II Travel...
Mar 23, 2009 | Garden
Reversing thumb controls
Your authorized Golden Technologies, Inc. dealer can reverse the thumb lever controls so that when you push on the “left” lever, your scooter will move in the forward direction, and pushing on the “right” lever will move your scooter in reverse.
If you don't want to go to a dealer, any mechanic who is willing can make this adjustment for y ou. hope this helps.
Feb 14, 2009 | Golden Technologies Companion II Travel...
Health & Beauty Logo
29 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
