Not heating comes up f01 - Washing Machines
How do I remove an error code from my front loading Maytag 3000 dryer?
The F01 code is communication failure, you need a main control board
May 31, 2015 | Maytag Dryers
Why is my Maytag Epicz model #MGDZ600TW2 not starting amd giving me an error code F01. What does it mean?
F01 is a control unit failure does this come up when you push the start button or did you go into diagnostic to get this code I have seen it come up as a false code check the start button does it spring back like all the other buttons if so replace control if not the button is broke
Jan 29, 2015 | Maytag Dryers
Indesit iwde7168 fault code f01 on drying
Indesit F01 is a board/motor fault, as it is happening on dry I would suggest looking at the board again ensuring there are no other blown solders or indeed the repaired solder connecting to another
Apr 07, 2014 | Indesit IWDE7168 Washer Dryer - White
Has an f01 error
The error code f01 indicates the primary control board failure. Before you replace that board I suggest that you unplug the dryer for 2 minutes then see if the error come back. If it does replace the board part number W10110641.
May 13, 2012 | Kenmore HE5 Electric Dryer
Model# 11087721700, with f01 error fix
Wf860 washer dryer - dryer has no heat and displays f01
Hi, Fault code F01 indicates a problem with the motor triac.Check all connections to and from the motor, the control module, and the motor plug
Apr 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint erorr f01
sounds like a faulty water valve regards jason
Jun 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
