1.ton ac capillary pipe size and length I want to know. B coz suction line cooling level is very low gass psi 75
  • Heating & Co... Master
  • 1,095 Answers
I'm guessing you should have 3/8 & 5/8 copper on that unit with a maximum of 50 feet. I doubt the line set size is affecting your pressures that significantly, you likely have a leak.
Posted on May 05, 2017
bobotfel
  • 236 Answers
SOURCE: 2 ton sanyo suction pressure erratic
Your suction pressure is erratic, your max. pressure is to much high. You did not measure your unit current reading liquid line press. to complete the data. But the problem of your unit is not the compressor its the system. Try to reprocess the system flush the unit with nitrogen, isolate the capillary tube and flush it with nitrogen to insure that no restriction.
Posted on Jan 04, 2008
22yooper
  • 828 Answers
SOURCE: ac freezes up
Exactly how much refrigerant did you charge into the system when you recharged it? If the suction pressure is varying that much you most likely over charged the system and got a liquid flood back which took out the compressor valves.
Posted on Jul 07, 2008
  • 146 Answers
SOURCE: AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
Posted on May 28, 2010
  • 127 Answers
SOURCE: AIR CONDITIONER IS NOT COOLING,
there is probably a leak in the systems somewhere, it needs to be inspected for a leak and charged with R-22 for proper cooling.
There is a stop leak for air conditioning systems available to licensed technicians to buy, might work if the leak is very small.
Posted on Aug 24, 2011
johnf1aresti
  • 1098 Answers
SOURCE: 2000 vw Jetta ac not cooling, ac compressor is on, freon level good, with ac manifold gauges high and low side fluctuates from 50-60 psi on low side.
try to throw cool water on the condencer front of the engine radiator and see whether any cool air comes in the car. If so see whether the pressure valve is working okey or not because might the pressure is not sufficient.
Posted on Sep 05, 2012
How much gass reqired in 1.5 ton ac r22
To many variables here to say. Pipe length, compressor size, acumulator, receiver etc. R22 very expensive here maybe not where you are.
Apr 20, 2013 | Fedders Appliance Air Conditioner...
Unit is freezing up
what type of gas?
if R410A it too low
if R22 check for inside air flow
Jun 23, 2012 | Gibson Nordyne/2 Ton Heat Pump Package...
AIR CONDITIONER IS NOT COOLING, USING GAGUE, FOUND BOTH SUCTION AND DISHCHARGE PRESSURE VERY LOW. IT IS R22 4 TONS AC UNIT, SUCTION 10 PSI, DICHARGE 80 PSI. COMPRESSOR AND FAN RUNNING.
Aug 22, 2011 | Heating & Cooling
I have a 4 ton outside and a 5 ton coil inside square footage of the house is 2495 living.my preasures are 75 low side and 225 hi side i'm not getting any flood back is this ok are do i need to add more...
Charging AC by superheat and subcool
First charging a unit by superheat, this is only for Acs with an orifice or capillary tube.
Optimum superheat is 12° to 15° at the compressor or suction line outside the unit.
Hook up your gages and put a thermometer on suction line (large line), start the AC. Measure the temperature of the suction line and read the pressure on your gages. Theres a temperature scale on your gages for R-22 or R-410A the needle will show you the pressure on the outer scale and if you follow it down to the R-22 or R-410a inner scale that is the saturation temperature for that refrigerant, (you can also use a temperature pressure chart), now read the thermometer, let’s say the suction temperature( the thermometer) is 67° and the saturation temperature (the gages or temp. press. Chart), is 55°, subtract the saturation temperature from the suction temperature, 67°- 55° = 12° superheat.
Charging by Subcooling, this is for Acs with a thermostatic expansion valve, it’s common to see a sight glass on the liquid line (on these units with a sight glass just clear it, when, indoor room is at approximate set point of the thermostat). Optimum sub cooling is 12° to 15° at the outdoor unit.
Hook up your gages and put a thermometer on liquid line (small line), start the AC. Measure the temperature of the liquid line and read the pressure on your gages. Theres a temperature scale on your gages for R-22 or R-410A the needle will show you the pressure on the outer scale and if you follow it down to the R-22 or R-410a inner scale that is the saturation temperature for that refrigerant,(you can also use a temperature pressure chart), now read the thermometer, let’s say the liquid temperature( the thermometer) is 100° and the saturation temperature (the gages or temp. press. Chart), is 114°, subtract the liquid temperature from the saturation temperature, 114°- 100° = 14° subcool.
Aug 09, 2010 | Amana Heating & Cooling
Air not cold enough to cool house
Make sure the outside fan is running. Also check the high side pressure, I assume the 70# is the low side pressure, so you can tell what the compressor is doing. If the fan and compressor are both working, make sure there is good airflow through outdoor coil and check that it is clean. Let me know what you find.
May 17, 2010 | Goodman CLJ24AR32 Air Conditioner
Hi everybody i want some help , iam a technision in air conditions ,i was fix a central ac carrier and i found that everything works good the compressor and the high pressure fan and indoor fan ,but the...
if the compressor is running - the suction pressure should be 65-75 psi - if it is very low - not enough freon - if it is very high - the compressor valves could be damaged - both will cause this
Sep 19, 2009 | Heating & Cooling
Ac capillary tubes
Sounds like you have a clogged cap tube. Yes they should both be sweating, I would expect your low side pressure to be lower though unless it is real hot in the camper. You can replace the tube but make sure what goes in is the same diameter and length because that is all engineered for proper metering into the evaporator.
Jun 11, 2009 | Dometic Rooftop RV Air Conditioner
Two lennox heatpump 71/2 tons
check the true psi with the line psi to see if same if psi is good in cooling 225 hi and 70 low on 80'day then compressor is fine and i would start checking for temp difference on the reversing valve sometimes this will cause high suction or high discharge psi shift it manually with by energising it be cooling or heating then pull wire and see how it shifts if shifts good then txv on out door unit could be bad what is the psi in heating on the discharge line going to the indoor unit? most prv's are set at about 350 psi r22 as for suction line size its only hot gas in hp mode os no problem their shows in cooling mode as low suction psi ..hope this helps some also make sure indoor coil is clean!....thanks & rate me
Apr 19, 2009 | Ruud UBHC Air Conditioner
Jan 04, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
