Question about Lands Phones
I can't change an existing price on a UPC. It shows the correct price when I enter it but it keeps ringing up at the old price
How to make it print a upc above $100.00
If your printer/scale is a Hobart system, it is programed not to print the codes so the checker has to look up the info and enter it manualy. This was double check on pricing. Depending the version of PROM board, the only way to get this changed would be to install new PROM's in ALL ot your systems components. Your best bet would be to contact your local Hobart service office and discuss the matter with the service advisor.
Apr 17, 2015 | Food Mixers
PCR-T500 shows the E037, Digit or amount limitation over when I press the CA/AMT TEND, where I receive the cash and try to give the change to my customer, it is work when I PRESS CR and CHK, but it show...
It happens when someone accidentally re-programs the cash button while trying to change prices because they are not following the pricing instructions correctly. Try programming the cash button as a zero price. Do it just like you are making a price change but enter zero into the cash button instead of an item.
For those who have asked about a programming manual for the PCRT500, one of the users has it here:
https://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T500_PCR-T520_Operation_and_programming_manual.html
Mar 28, 2015 | Retail Supplies
How to scan upc with price pcamerica
is the software install, it the scanner working properly check the drivers for the scanner and software up to date, depending how the price check software is set up and how the price check key is labeled so you know how to do it
here is 2 sites that maybe help you see some one else can show you how every thing works.
www.yoube.com
www.howto.com
other info and websites
www.ask.com
www.info.com
www.about.com
www.wiki.org
wwwwikidea.org
write your questions like this:
how do i scan upc on my pcAmerica cash register
how to operate pcamerica register
how to scan items on express 1 pro retail stationpro
www.pcamerica.com ?
www.searchall.com/manufactures name/model ##/manuals
www.searchall.com/xxxxxxxxxxx/xxxxxxxx/manuals
good luck rod
Mar 03, 2015 | pcAmerica Cre Cash Register Express 1 Pos...
UPC code85948500222
Hi. I'm not sure if this will help you, but I found this website:
UPC Database Item Lookup
According to this website:
"Enter the all digits printed on the UPC bar code, including any numbers to the right or left of the bar code itself, even if they don't line up with the main row of numbers. This should be 13 digits for an EAN/UCC-13, 12 digits for a Type A UPC code, or 8 digits for a Type-E (zero-supressed) UPC code. Anything other than 8 or 12 digits is not a UPC code! (And just because it's 8 or 12 digits doesn't mean it is a UPC.) You must enter every digit here.
If you have a barcode scanner that outputs plain numbers, you should be able to use it to enter the UPC number here."
So, apparently you need more digits to complete the bar code #. But if you have the full barcode, you should be able to enter it on the website linked above, and find the image of the frames that you are looking for. I hope this helped. Thanks!
Oct 23, 2014 | Datalogic QuickScan QS6000 Plus Bar Code...
Ipad 2 problems
Reset the iPad, then enter correct info.
Feb 03, 2018 | Apple Ipad II 32gb 2nd Generation -...
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
Relacing a fuel tank sending unit
Hi Thom, I would suggest getting a replacement with the correct fitting. A good place to find something for a reasonable price is a salvage yard. Fitting a generic component is risky, especially so with a fuel tank. It would not be good to be leaking fuel everywhere. Let your imagination take you to a place where there are carefree smokers around. Regards John
Sep 09, 2012 | 1990 Jeep Cherokee Limited
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I need to change which phone rings.
I guess this is alittle late... but for your knowledge:
First you need to know the extension of the phone that you want to change. Feature 0 at the phone you want to change and hit the intercom key to ensure that we are programming the right phone.
To get into programming press:
-> FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will have to look at your LCD for 3 arrows
<- Heading..Enter->
<- Back .......Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension number of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Enter (the top right arrow) again then LINE ASSIGNMENT and hit Enter again
-> then you will see Show line:____ and input 001
-> it will show something like L001: Unassigned now press CHANGE till it says Appear&Ring
-> keep putting in all the lines that you want to ring at your desk
till all the lines are found (the numbering scheme counts out funny for Norstar it goes: line 001,002,003,004,025,026,027,028)
-> after you find all the Lines, you now hit RLS to back out of programming.
Voila, your phone will now ring. To change back, do all the same steps, but input Unassigned instead of Appear&Ring.
Apr 03, 2009 | NorStar Meridian M7310 Phone
Jetway 939 gt motherboard install
What install disk are you talking about, and sorry ,need to know the error too.
Nov 18, 2007 | Jetway 939GT4-SLI-G Motherboard
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
