Question about Xerox Office Equipment & Supplies
Xerox 3615 printer getting error 050-130. and taking out the paper once doesnt help it happenes again
  • 417 Answers
SOURCE: False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Posted on Dec 31, 2007
  • 2072 Answers
SOURCE: Xerox Phaser 850. Unexpected repeat printing
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
Posted on Mar 31, 2009
  • 214 Answers
SOURCE: Paper is jamming all the time
You will need a tech guy to fix this. Sorry to dissapoint
Posted on Apr 27, 2009
  • 26 Answers
SOURCE: HP Officejet Pro L7780 constantly gives false"paper jam" error
Step 1:
The rollers should be cleaned if the paper fails to feed smoothly into the unit. All document and media rollers should be cleaned using a lint-free cloth lightly moistened with water.
1. The unit must be powered down and the power cord unplugged before cleaning the rollers. This will allow the rollers to be turned by hand in most cases. The paper should also be removed before cleaning the rollers.
2. Remove the rear access door to access the rollers. Clean any dust and debris from the rollers.
3. Open the unit and check the four small metal paper rollers (not the rubber rollers) in the interior of the unit. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the unit and reattach the rear access door.
5. Plug the power cord back in and power the unit up. It should reinitialize for about 20 seconds.
6. Print another extended self-test page.
Step 2:
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+) instead of #.
==== Semi Full Reset ====
Press and hold # and 6 button on the unit while plugging in the power cord.
NOTE: For models that are not fax capable, press plus (+) instead of #.
==== NVM RAM Reset ====
Press and hold OK and Cancel button while plugging in the power cord
Posted on May 19, 2009
  • 4041 Answers
SOURCE: Error code 10-356
10-356 code i pws mode
remplace the fuser
Posted on Feb 10, 2010
I am recieving the error 062-360 "scanner home position sensor error" when i first turn on my brand new printer
did you remove all the items that were there only for locking things for transportation? was the scanner blocked in this way, too?
Aug 21, 2014 | Xerox WorkCenter 3615/DN Mono Laser...
Xerox errors
Ink contamination use clean ink smears several time to clear, if that doesnt work replaceing the in resevior is the only option
Jul 22, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
What is wrong with my printer
I get this many times but I always see the paper jammed when I open it up. Once I removed the sheet which seems to stop at the transfer roller, I restart but it sometimes happens again.
One has to check the paper in the tray and see if it is free inside the top of the tray.I move the pickup.
Have you turned it off for a few mins then on again. Tried different paper?
Good luck
Jul 17, 2014 | Xerox Phaser 6250 Laser Printer
ERROR 024-959
Xerox 6605 paper tray empty error, the paper detect sensor arm and pick up roller get out of place. remove paper detect sensor arm and pull down on pickup roller assembly it should be springy not stiff. once it springs again, put paper detect sensor lever back on, on the right side of that lever gets tucked behind pickup roller assembly. hope this helps. The Magic Man!
May 29, 2014 | Xerox WorkCentre 6605/N Color Laser...
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam:
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
Papaer empty
it first detects that no paper in the selected paper supply and it cause an error to your computer memory and printer memory so you must reset the job to clear the error on its memory to the two units.
May 15, 2010 | Xerox Phaser 7760/YDX Laser Printer
Xerox PE 120i workcenter. Error says
you need to remove your paper tray.take your toner carriage out ,yurn the mc and assess
Nov 29, 2009 | Xerox PE120i Laser Printer
Paper jam error comes up and can't clear it. Doesn't appear to be any paper stuck in printer anywhere
please double check again your printer by re-opening it.
look very carefully maybe there was still a small paper inside your printer.
after that try to turn it off your printer then afer 5 mins yiou can turn it on again.
any changes happen and further question don't hesitate to contact me.
Mar 21, 2009 | Xerox Phaser 8200N Printer
395 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
