Question about Tablets & eReaders
Fire tablet won't charge
I have replaced the battery with a genuine article that was 50% chargedo I proceeded to plug it in to fully charged it after 8 hours the charge had not increased. After the battery drained I plugged it in and the lightuning bolt showso it is charging but it will not go above 1%.
    New Friend:
I called Amazon and went through a 15 min troubleshooting session with support. Since mine was only 10 months old they sent a replacement. When it happened to the replacement it was 3 years old so I had to buy a new Fire - they forums say it's the charging portal.
Posted on May 05, 2017
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
My kindle fire hdx 7 running lollipop 5.1 is charging but not keeping the power
Hi try another charger could B an intermittent fault with charger.if it's not the charger it could B a fault in the tablets charging circuit or a faulty.,,,, battery good luck
Mar 06, 2016 | Amazon Kindle Fire HDX 7
My kindle fire does not keep its charge. I can use it one time and during the ap it goes dead
If you charge the device fully, meaning 100%, and while using it with a simple app it doesn't last 2 hrs. then you need to replace the battery. Next time it goes dead, don't turn it on, instead plug the charger and let it charge to 100% while the device is off. Once is fully charge, use it as you would normally do. But still,it needs a new battery.
Apr 30, 2015 | Tablets & eReaders
Battery will charge to 100% only 50%
Morning Emily,
A couple of questions, then a couple of ideas.
  1. Are you using the charger that came with the tablet or are you using a universal charger?
  2. Do you leave the tablet on the charger a lot of the time or do you only charge it when it gets very low on charge?
Often devices like these need to be drained periodically so that your battery does not develop a shallow cycle. Shallow cycle can often occur whenever a device is charged often before it actually gets down to a low percentage of this battery capacity. If you have been typically keeping it charged without letting it drain I would suggest leaving it on and letting it drain fully and then try to recharge again.
If you have not been doing constant charges as described above, then it sounds to me like either you have a bad charger or there something wrong with the battery in your device. I'm going to provide a link to a Page on the next book site so that you can see some of the information related to your device.
I think the biggest questions to be asked are, a) is the charger that you're using putting out sufficient power to charge the battery properly, or b) is the battery in your unit defective. These questions can probably be best answered through the store which you purchased it, such as a Best Buy or wherever it is that you got it. They should be able to analyze the output of the charger to see if it's correct. If it is correct and again if you've not been doing the shallow cycling then that would indicate a problem with the battery.
I'm including some links below that might be helpful for you. The first one is to a knowledgebase article dealing with battery and battery life. The subsequent links are for the manual and also for the technical specifications for your device. The tech specs will probably help as far as your battery and also what should be the output of your charger.
Knowledge Base:
http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/71/23/battery
Links:
Manual http://www.nextbookusa.com/pdfs/NEXT8P_Manual.pdf
Spec Sheet http://www.nextbookusa.com/pdfs/NEXT8P_Spec_Sheet.pdf
I hope this helps.
Dec 27, 2014 | Nextbook Premium 8 Se Android
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
Kindle fire won't charge
You may need a new power cord or it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't charge this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
Sep 24, 2012 | Amazon Kindle Fire HD
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Dec 09, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
62 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
