Question about LG Washing Machines
The machine won't finish and open.
Its an LG Direct Drive 8kg F1289TD5, I put a wash in it and it won't finish as soon as it reaches 10 minutes it won't go any further?
  • LG Master
  • 2,320 Answers
Any error codes?
Posted on May 05, 2017
Aquasmart 8Kg washer- spin cycle short
my problem is I did two wash and then I put two thin curtain in to wash and that is when I had this problem
Jul 07, 2013 | Fisher and Paykel Aquasmart wl80t65c
Where is reset button on lg direct drive 8kg washer
What is the model number of your unit?
Nov 18, 2012 | Washing Machines
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
Oct 14, 2017 | LG Washing Machines
LG Washing Machine makes a groaning sound.
Its most propably bearings on the drum,normally the seal in front of the bearings is leaking ,allowing water into the bearings, which destructs them..
It is bigger job to take the drum apart but do'able with basic tools.
If possible, source the seal and bearings beforehand.
Another factor can be overloading,try lightening the loads first..
Oct 05, 2012 | LG Washing Machines
I have a LG direct drive wahing machine and its flashing IE cant find manual what does it mean please help!
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. Check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. If clogged, water will not flow through these filters into the washer. Disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg If this doesn't work then you will need to change the water inlet valve by removing the top panel.
Mar 15, 2011 | LG Washing Machines
Reducing the noise when the washing machine is on spin cycle
Nothing is wrong w/ the unit. It must be solid on the floor with no movement in the feet relative to the flooring or it will rock when spinning. Floor is simply not solid enough. Use slower spin speed to alleviate issue or relocate it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 28, 2008 | LG Washing Machines
Lg wm-14445fds direct drive 8kg washing machine manual
You can get the manual here:
http://uk.lge.com/products/sidemenu/list/homeappliances|washingmachine|steamdirectdrivewashingmachine_PRD|MANU_manu.jhtml
Just curious - what happened when you tried to get in touch with LG? Also, did you call, email, what?
Aug 07, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
