Question about Xerox Office Equipment & Supplies
I have a Xerox phaser 6510 laser printer and when recooting shows a msg ' Switch power OFF and then ON' 124-315 but after switching off, error come again
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
  • 2072 Answers
SOURCE: xerox phaser 6180n :erorr msg 1) "motor erorr" 2) "error 042-325"
Your main drive motor is either not statting or the main board is not sensing it. You can remove the covers, WITH THE MACHINE UNPLUGGED !!!!!!!!!!!!!!!! and reset all the connectors, check the drive motor, and see if maybe a gear is broken., If the machien is less than 1 year old. Call 1-800-835-6100. You will have some kind of 1 year warranty, Either on site or in depot repair, which would mean they will ship you a new machine with a box to return the one you have. If you call, make sure you have the serial number handy so it can verify the warranty.
Posted on Dec 02, 2008
SOURCE: PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Posted on Jan 17, 2009
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
Dadofmykids
  • 25 Answers
SOURCE: Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Posted on Apr 07, 2009
I have a Xerox Phaser 6360 with a ram error what could the problem be?
Are you sure it is not a NVRAM error you are recieving?
If yes, remove the IMAGING UNIT.
Close the door and Power On.
Msg gone? If yes, replace IMAGING UNIT.
If no, remove the FUSER unit.
Close the door and Power On,
Msg gone? If yes, replace FUSER.
If not, it is the ENGINE BOARD.
Oct 24, 2012 | Xerox Phaser 6360 Laser Printer
Error 08,035.42:7417 after power loss. on 8650 phazer
my xerox printer phaser 8860 is stop printing. message show, 08,035.42: 138484. Is this fixable
Apr 05, 2011 | Xerox Phaser 8560DN Laser Printer
Xerox phaser shows error code 007-274. -john
what model phaser there are so many and not all codes are alike yours might indicate a tray 2 power on jam
Dec 22, 2009 | Xerox Phaser 7760/YDX Laser Printer
Xerox phaser 3200mfp We are able to fax out, but all inbound receiving faxes are getting a busy signal and not coming through. There is no error msg of any kind. please help.
Get a older phone and hook it up. Try to call that number and see if you get though. My guess would be this is a prefix error (not putting a 1 in front of the area code, ect.)
Jun 24, 2009 | Xerox Phaser 3200MFP/N Laser Printer
Error in xerox phaser 8400
37,004.40: PEST - Printhead Reservoir 0 disconnect. Reservoir 0 is not drawing
the expected power from the supply.
One of the printhead cables may have come partially unplugged. Also, an ink spill on the circuit board could lead to this problem.
Apr 13, 2009 | Xerox Phaser 8400 Laser Printer
Change ink cartradge 11ER00670, same error after new cartradge.
SYSTEM NEED TO BE RESET, CARTRIDGE MAYBE DEFECTICE, THE SWITCH MAYBE A PROBLEM, GO ONE LINE AND SEE IF ANYONE ELSE SEEN THESE TYPES OF PROBLEMS, GO ONLINE AND TYPE:
XEROX PHASER 5500N LASER PRINTER CARTRIDGE ERROR 11ER00670
ENTER
IF THAT WAS THE ERROR NUMBER YOU HAD
OR
XEROX PHASER 5500N LAZER PRINTER CARTRIDGE ERRORS
ENTER
OR
XEROX FOREM GROUP
ENTER
OR
MANUFACTURE NAME,MAKE,MODEL, DRIVERS AND SERVICE MANUAL
ENTER
ROD
Feb 09, 2009 | Xerox Phaser 5500N Laser Printer
324 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
