My charger went bad. ordered a new one. but I hear 5 beeps constantly, what should I do
    Sergeant:
  • Computers & ... Expert
  • 278 Answers
Need to resolve laptop brand and model.Ex .dell inspiron 3521 5 beeps means RTC Error. need to replace the CMOS Battery and check. if not working pls check south bridge is heat up.
if heat up need to use cons to set heavy load to chip and (3 coins) pls use hot gun to resold the chip.
Posted on May 05, 2017
Constant beeping on radios
Bad batteries, no matter what the charger says. Especially true if lithium ion. You could have the radios on the charger and still get beeping if bad. Replace and post if this did not fix the issue. OR, it is a bad charger, use more than 1 charger if you have them.
Apr 22, 2016 | Radio Communications
MY i pad will not charge
As soon as you connect your iPad to a working charger, it will beep. If you plug in the cable and you don't hear the beep, assume something is wrong. Just find out what, the cable or the charger.
Don't try to charge the iPad with a computer, because the 500 mA a USB connector from a computer can give, is not enough even to start.
But you can use a computer to test the cable, because the iPad should beep and say on the screen not charging.
If there is no beep when connecting to a computer, you have to use another cable. If it beeps, buy a new charger. 5 Volt 2 A. The best an Apple charger.
Jul 17, 2014 | Apple iPad2 WiFi 64GB
Lenovo 3000 g530 4151 battery is not charging,give the solution
When you connect and disconnect the AC adapter, do you hear a beep? If you do not hear a beep, check the AC adapter for the following.
1. Check that you have power at the plug in the wall. Don't laugh, this happens.
2. Check the cable that plugs in the wall is fully plugged in the adapter. It needs to be fully seated.
3. Check the cable that plugs into the computer. Make sure is not damaged from running over with chairs, etc. or maybe someone tripped on the cord and damaged it.
4. Measure the voltage at the plug with it disconnected from the computer. It should be the same voltage as marked on the sticker. If you are not getting the correct voltage change the adapter.
5. If you are getting the correct voltage, you may have a bad battery, or a bad motherboard. Replace in that order.
Feb 04, 2014 | Lenovo 3000 G530 4151X3U Laptop Charger...
2004 chevy malibu I constantly hear a beep inside my car. What can it be?
The beeps happen when speeding up and passing other car
Jan 18, 2012 | 2004 Chevrolet Malibu
No picture for ps3,i went to service menunand did something wrong
You probaly turned hdmi on or off i dont know what your settings is,
you can turn your system settings back to factory default using the Safe Mode.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
    safemode2.jpg //
Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
I hear 5 warning beeps then a pause then 5 beeps again
Get the battery situated, and your beeps should go away. Sounds like an errant security horn from a sloppy connection. Interested to see what happens. TT
Jan 28, 2009 | 2001 Ford Explorer Sport Trac
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Control locked on, can't release it
find button with lock emblem hold 3-5 secs if will not clear suspect either bad interface(buttons ) or bad connection or broken wire between front panel and interconnect on main control
Nov 26, 2008 | Whirlpool GEW9250 Electric Dryer
Recharging phone constant beep
When misplaced in the charger the xg2200 beeps, are you sure the phone is placed correctly? please let me know. Good Luck
Mar 01, 2006 | Xact Communication XG2200 Cordless Phone
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
