Question about Pool & Spa
Pool heater comes on and gas enters unit for about 5 seconds and then the gas shuts off. natural gas
    Visited the website for 60 consecutive days.
  • 121 Answers
You will first need to figure out if you are getting ignition during the 5 seconds or if the valve is opening with out ignition.
If you have NO flame, inspect the ignition source. Make sure you have proper ignition.
If you DO have a flame, inspect the flame sensor. Replace sensor, do not try to clean sensor or jump sensor out. The flame sensor is part of a rectification circuit and the heater needs a well connected ground to work properly.
I could help more if I had the model and make of the heater.
Posted on May 06, 2017
  • 36 Answers
This could be the flame sensor. If you can look into the firing chamber there should be a steel rod about 5" long that dangles into the gas fire jets. Turn off the unit. If you take the fire sensor out and gently rub it with steel wool and replace it, it may start working again. If it does, great, but order a new fire sensor and replace the old one when it comes in. They are very cheap.
Posted on May 05, 2017
I am getting an error code ags
AGS - Auto Gas Shutoff = Because of a problem sensed, the gas valve is closing, stopping gas supply and hence heater shutoff.
Improper water flow through heater! Check filter, pump, water supply lines, anything that will reduce water flow into heater.
A faulty Pressure Switch may cause this problem as well.
In coming water to heater is over 104°
If all is good with the above, replace the AGS Switch.
May 31, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Upon start heater comes on for about 5 seconds and shuts down. Then starts again and stops again, and so on. "PRS" appears
PRS means the pressure switch is opening and shutting off the heater as you describe. Either your filter and/or inlet baskets need a good cleaning or the pressure switch in the heater is failing. Try a thorough cleaning first and then replace the pressure switch if necessary.
Oct 25, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
(natural gas) the heater comes on for 3-5 minutes and then shuts off, and won't work again for hours. this is a shred heater between the pool and hot tub, but never used for the pool.
Check your high limit switch inside of the heater. Usually when the high limit switch pops it will take about 4 to 6 hours for it to reset itself without you resetting the system.
May 16, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Blown Heater blower motor
you will have to replace the brain unit its shorted out
Jan 26, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
