Question about Samsung Washing Machines
Samsung front loader washer has SE error - Samsung Washing Machines
    Top Expert:
  • 867 Answers
SE is spin error, it means that either there is something stuck in the pump or the hose between the drum and the pump of or the pump and the drain are blocked.
Alternatively it could also mean a faulty pump if there is nothing stuck in any of these places.
Posted on May 15, 2017
I have a samsung front loader that has error code of SE on the screen and is not completing a full cycle.. what could that be
Hello!
"SE" error basically means:
High/Low voltage detected.
How to resolve:
Restart the cycle.
If the code reappears, call for service
I also add a link to the manual to a Samsung washing machine. Hopefully, it will help :)
http://manualsbrain.com/en/manuals/1797935/?page=33
Jul 17, 2017 | Samsung Washing Machines
Samsung washer spinner is not spinning
Model number? Top loader? Front loader? Any error messages? Is it doing anything else or is it just dead?
Nov 13, 2016 | Samsung Washing Machines
My front loader washing machine samsung has an error SE. What does this mean.
Contact supplier and ask them the question.to get the right answer.
Jan 09, 2015 | Samsung WF337AA Front Load Washer
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
7kg 1045 front loader, says SE or 5E wont drain, will open fill and wash but not draining
Hello & Welcome to FixYa
5E is a water drain error and occurs when the water level frequency does not show changes. First clean the debris filter located at the bottom of the washer and then turn the unit back on after 15 minutes. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Samsung Washing Machines
Washing machine comes up with error code se and won't drain the water or perform a spin, on model Samsung J1453SGS/XEU
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Washing Machines
No water is going into my bowl after I fixed mt SE problem
This is a defective inlet water valve assembly. replace it asap.
Jun 24, 2009 | Samsung WF203ANW Front Load Washer
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
LG Washing machine - Front Loader
Suggestion: Check your outlet filter, it could be blocked. I looked for this SE could not find it.
Jan 15, 2007 | LG WM1812C Front Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
42 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
