Question about Dewalt Planer (DW734)
Need manual for sunhill 15 planer planer is 30 years old.
Need to make adjustments and need manual for support.
I have a wide belt sander that was made by Sunhill Machinery. I bought it used and it has has a digital controller. The manual does not give any instructions on how to use the controller and I have also...
I have a Reliant 6" belt/disk sander
Reliant dd79 3/4 hp, which is suppose to rise to a vertical position.
I need a manual for this.
e-mail delhotel@comcast.net
Jan 07, 2011 | Sunhill Machinery Sunhill Spiral...
I need a SMALL PART FOR MY SUNHILL 15" OPEN ENDED WIDE-BELT SANDER. WHO SHOULD I CALL?
As you may have discovered, Sunhill Machiney is out of Business. Story I have is that the owner is deceased and that the descendents are either liquidating the company or planning to move the company to California, but that is rumor.
Three options:
1. Most of Sunhills machines were made by Geetech. You may have some luck contacting them directly. Geetech
2. The Sunhill operation was/ is in the same building with Oliver. Coincidentally, Oliver also sources many machines from Geetech. You may have some luck contacting Oliver directly and politely asking if they know anything about who to contact for parts or (perhaps) the Oliver machinery may be similar enough that the part you need may interchange.
3. Steel City also offers a 15" widebelt sander. You may have some luck in parts interchange there as well. Steel City customer service
Hope I have been helpful.
Regards,
Grant in Iowa
Dec 20, 2010 | Garden
Need a manual for acme juicer 6001, juicer at least 30 years old
The juicer hasn't really changed over time, but you
need to be a little mechanically inclined to adjust
and keep it running properly. Call Waring at tel
1 800 492 7464. Good luck. Mine is 21 years
old and running like new.
Jul 30, 2010 | Acme 5001 Supreme Juicerator Juice...
Have Powermatic Planer & can't get the infeed & outfeed rollers adjusted right. Takes all you have to operate it. 24" Planer less than 10 years old & probably doesn't have 200 hours total on...
The rollers may need to be reconditioned. Try cleaning with a solvent to soften them up. I hope this has been helpful please rate if this answer has been of any help. Good Luck and have a great weekend.
Apr 02, 2010 | Powermatic 1791268 201HH 22" Planer w/...
I have a Jet planer 15 and the wood gets stuck
I think you are trying to remove too much wood in one pass.Don't cut so deep and see if it will feed thru then. hope this helps you
Jan 17, 2010 | Wmh Tool Group Jet 13" Planer Molder
Delta rockwell 22-200 planer. I need a manual.
Check on www.owwm.com. You will probably find your machine on their and resources to help you in your quest. It's a great site for old tool hounds.
Jan 08, 2010 | Delta Masonry Tools
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
Dewalt DW733 Bench top thickness planer How to change blades ?
OK you need to go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number it will take you to another page and then find your type number and click on the instruction manual section on the right side, I clicked on type 2. This manual is about 30 pages long. Let me know if you still need help and if I have helped could you please rate the answer accordingly. Good luck
Apr 16, 2009 | Dewalt Tools & Hardware - Others
Help i need to change my Dewalt DW733 Planer Blades i lost manual
try dewaltservicenet.com They have manuals as well as parts breakdowns.
Apr 16, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Need a manual for a 15'' planer
Why should I tell you for free how I fixed the problem when you want to charge me for your solution?
Mar 30, 2009 | Masonry Tools
Dewalt Planer (DW734) Logo
239 people viewed this question
Top Dewalt Crafts & Hobbies Experts
Ivan
Ivan
Level 1 Expert
CliffOnTheRo
Level 1 Expert
Tony Crow
Are you a Dewalt Craft and Hobby Expert? Answer questions, earn points and help others
