Question about Samsung Dishwashers
Samsung dmr77lhs - Samsung Dishwashers
2 Suggested Answers
Hugh fulton
  • 62 Answers
SOURCE: bad smell from my samsung dmr77lhs dishwasher what to do?
Put about three or four drops of eucalypt oil into your dishwasher and put it on a wash cycle - you don't need to use the drying cycle. Then is should smell beautifully. It's probably just the newness of the machine with seals and parts all giving off the smell. If that doesn't work contact the dealer and get them to find out what it is. After all you paid good money for it.
Good Luck
Posted on Sep 13, 2009
Samsung dmr77lhs dishwasher not turning on
Make sure power is present to the dishwasher from the wall plug, then if that is ok you most likely need to replace the control panel assembly. Cost about $200 US installed on average
Jan 24, 2017 | Samsung Dishwashers
Samsung error E5
I don't know about a E5 error; are you sure it's not a 5E error? That means a drain error or "water not draining" error. Check the drain pump and drain hose for an obstruction. If that's okay, and the dishwasher drains water, then you probably have a bad ECS sensor.
Mar 30, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
Samsung DMR77lhs drain pump wiring
The orange lead goes on the connector on the edge of the pump. The white lead goes on the connector toward the middle.
Jan 08, 2012 | Samsung DMR77LHS Tall Tub Dishwasher
My Samsung dishwasher model # DMR77LHS makes this terrible grinding noise when it is initially turned on & then 2-3 more times through the cleaning process.
Mine make a grinding noise also when the wash cycle starts. I had a repair guy over fixing my fridge and he said it was the washer motor. My machine has only been in use for 1-2 yrs. Other owners say that the tabs on the top rack break off and get lodged in the machine. hope this helps a little.
Dec 26, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
My samsung dmr77lhs LE light keeps flashing how do i reset this garbage machine? Resetting the power does not work. Please help
I have the same problem with my dmr77. My coffee pot ran over and evidently ran down behind the Samsung dishwasher. It thinks that it is leaking. How do you reset it?
Oct 06, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
My Samsung DMR77LHS dishwasher has NO power showing on display board, checked electrical hookups it ok. Outlet has power. Pressed Power On/off button, no response, all lights are off...
hti had athe same problem, and the fuse fixed it. it turns on now,
you can get to the fuse casing, small tube about 1.5 inches , black, by flowing the electrical line to the, inside , or the under carriage, on the side of the bottom of the unit.
15 amp 250 volt at radio shack.
Sep 12, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Samsung DMR77LHS Dishwasher has power to dishwasher, ciruit breaker is on. Lights on door will not light up, nothing will work
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
Apr 12, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Dishwashers Logo
27 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
