Question about Plumbing
Kingston kitchen facucet -- no water coming out at all
2 Suggested Answers
  • 92 Answers
SOURCE: just installed a kitchen faucet and now it leaks when on at the b
sounds like you may have clogged the little screens at end of spout try unscrewing and see what happens if not you may be suffering from the returned part open box syndrome
Posted on May 11, 2009
Do you have a handle set with a 7 inch spread instead of a 8 3/4 spread and model #
Yes we do. how many would you like?
  • Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount ... www.amazon.ca/Kingston-Brass-CC543T8-Vintage-7-Inch/dp/B0026ZPI0Y
    • KINGSTON BRASS
    Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount Leg Tub Filler with Hand Shower, Satin Nickel in Showerheads & Handheld Showers.
  • Kingston Brass KB967 Magellan II Widespread Lavatory ... www.amazon.com > ... > Rough Plumbing > Faucet Parts > Faucet Handles Kingston Brass KB967 Magellan II Widespread Lavatory Faucet 8-Inch to 16-Inch Centers 7-Inch Spout Reach, Satin Nickel and Polished Chrome
  • images of 7 inch spread faucet bing.com/images th?id=oip.m9aaf750d3da8ce6a24cbe32ef9078ae8o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m643aef6e35c24789db3419b21dd47a91o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.ma09426c72dcc25d64ff92045ab194af1o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9b0dc70d9ab53ad1ecca18fd130db74bo0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9afd6495c16d35699054f30b9ee4d7e7o0&w=104&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of 7 inch spread faucet
  • Water Creation F6-0007-05 Vintage Classic 7-inch Spread ... www.overstock.com > ... > Bathroom Faucets > Water Creation
    • 5/5
    • 1 RATING
    • $409.17
    Shop for Water Creation F6-0007-05 Vintage Classic 7-inch Spread Deck Mount Tub Faucet with 2-inch Risers and Handheld Shower. Get free shipping at Overstock.com ...
  • Apr 16, 2016 | Plumbing
    The spray handle works but the faucet does not. water trickles out of the faucet...spray handle is leaking under the sink. faucet is only 1 year old.
    wow need a new faucet?? NO just kidding
    Ok the water not running out of the faucet. that is the screen on the end of the spout, just un screw it clean it and your good to go.The leak on the spray, pull the spray out and run it and look at the connection right there on the handle.
    if there is no leak, get an other person to run the sprayer and you take a flash light and look up at the bottom of the faucet.and see if you can see the leak from there. The hose should attach to a brass section coming out of the bottom of the facucet, It may be it just got loose and you need to re tighen it. Now yo will need a basin wrench to do that . If yo dont have you you can buy a cheap on ( which is all you need) from a hardware store,
    Also if you take your hand and feel around the the bottom of the sink where all the pipe come down it might be the fauect itself.
    Good hunting be safe protect your eye
    Tom
    Sep 11, 2011 | Price Pfister Marielle Kitchen Faucet with...
    Replaced back yard facucet now water wont turn on
    make sure you have water coming to the tap, if so then you need to take the tap apart theres an inside seat there that you can adjust for more or less flow
    Jul 29, 2011 | B&K BK Mueller 122048RP Single Lev Kitchen...
    New Kingston Faucet has continual leak (when it is used) from the sprayer... where the spray handle connects to the hose.
    unfortunately this is a common problem with sprayer heads, check the rubber gasket for any defects and also check the gasket seat on the sprayer end and the supply line end for any debris or defect. sometimes the only way is to replace the sprayer itself.
    Dec 07, 2010 | Kingston Brass Chatham Satin Nickel...
    Just installed a kitchen faucet and now it leaks when on at the b
    May 10, 2009 | American Standard 1340M.105.002 Polished...
    No hot water
    if the leak is behind the handle take the handle off and tightn the packing nut, do not over tighten, as far as luke warm water is this with just one facucet on, they way these tankless water heaters work they are by gpm, gallons per min, if you have more gallons of water going thru the unit then it is designed for then it won't get hot, if your water pressure is to high going thru it will push it to fast thru the unit and won't get hot, your house pressure should be no higher then 75lbs no lower then 65lbs
    Feb 25, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
    Plumbing Logo
    181 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
