Question about Yamaha Computers & Internet
Yamaha timberwolf 250 weak fire out of coil no fire end of plug
Help
  • 9 Answers
SOURCE: won't idle steadily
Check the rubber boot that joins the carby to the engine to often have seen the hose clamps over tightened therefore creating a split in the rubber letting to much air in giving the rough idle eventually you wont be able to start it at all (have a good thorough look inside an outside of boot doesnt take much)
Posted on May 22, 2009
ollie reece
  • 1167 Answers
SOURCE: WHAT ARE THE ORIGIONAL SIZE TYRES FOR A YAMAHA
hi buddy
front=22x7x10
rear=22x10x10
Posted on Sep 19, 2009
Testimonial: "very good and accurate and very quick "
SOURCE: what is valve clearance for a 250 yamaha timberwolf
what an *******. If I had a manual or my library had one I wouldnt be asking the question. If I need help fixing something dont tell me to go jump in a lake just dont answer
Posted on Nov 08, 2009
  • 11 Answers
SOURCE: Need to find serial number on 1997 Timberwolf 250
It should be stamped on the left hand lower frame.
Posted on Feb 06, 2010
ibrown1967
  • 450 Answers
SOURCE: 1995 250 timberwolf wont fire and need to find electrical wiring diagram
is there power to coils, ht lead and cap ok, is spark plug ok, are you sure its an electrical fault
Posted on Feb 21, 2013
1999 Yamaha Timberwolf 250 will not turn over. Took it to someone they said it was stator. Replaced stator and spark plug still wont turn. There's no noise anywhere.
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
1994 Yamaha Timberwolf 4x4 Electric Start Problems
no fire 96 timberwolf
http://www.mikekekich.com/92-98%20Timberwolf%202WD%20Service%20Manual.pdf
OEM parts for Yamaha
Yamaha YFB250K Timberwolf Owner Manual
Jan 13, 2017 | Yamaha Motorcycles
Yamaha Timberwolf. How can I find model number to order parts
If you can tell me your vin - or your year I can tell you what model you have. But - if you go onto any parts site - such as cheapcycle.com or partsmonster - you name it - you won't need your 'model' # - just your year. You'd click - Yamaha OEM Parts, then ATV then Year - 1992 - 1998 was the Timberwolf - a lot of parts from the 99 - 04 Bear Tracker will work (just about only changed the plastics and carb in 99 - 04) same engine/transmission/rear end, etc. the brakes also went from drum to disc - but you'd click on the year - and then look - the timberwolf will be right there the 1992 - 1998 Yamaha Timberwolf 250 - I can't remember if they offered a timberwolf 350. If you can tell me the vin or year - like I said - I'll reply with your exact model # - but you can buy and order most parts just by model name and year 95 Timberwolf.
Dec 29, 2015 | ATVs
1994 Yamaha 250 timberwolf piston ring replacement
YAMAHA TIMBER WOLF 250 ENGINE OVER HALL ANN ...
? 3:08
www.youtube.com/watch?v=0fypjxwZV40
May 16, 2010 - Uploaded by omar arriaga
HERE IS MY NEW PROJEC PAINTING MY 250 TIMBER WOLFIM REPARING ... back break replacement on Yamaha timberwolf 250cc tutorial ...
Sep 12, 2015 | Yamaha Motorcycles
How do you check the coil firing on a 97 timberwolf 2x
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
How To Test Stator coil
How to fix No Spark Problem on Motorcycles and Dirt Bikes
ekak visualdns net
http://mybikemanuals.com/yamaha/yamaha-tz-owners-manuals
Jul 08, 2014 | 1995 Yamaha TZR 250 R
1997 yamaha 250 timberwolf overheating
look for the thermstat and change out because of sticking.Over heating will cause rings not to have the ridge force needed to keep compression at normal .
Jun 03, 2014 | Yamaha Timberwolf 250 2wd 97 Airbox Air...
Yere my 1996 yamaha atv timberwolf when i apply the rear brakes the brakes stay on and dont click of whats the problem
The Timberwolf has a cable operated brake system, not a hydraulic so there is not a master cylinder. Most likely causes are: mud in brake drum, broken/weak return springs (inside brake drum) or a sticking cable. Take off rear wheel to access the drum, and then remove the drum. The problem should become clear. BTW..hydraulic brakes use brake fluid, not oil.
Jan 15, 2010 | 2003 Yamaha YZ 250
Nov 27, 2009 | 2008 Yamaha Yamaha G5
Yamaha timberwolf wont start unless push started
You have a loose connection to the ignition system . When cranking make sure it is in neutral. and kill switch is in run position. The only thing dropping would sensibly affect is the fuel system or jarring a switch., but with the suspension you have there really is no jarring. So, I would ck the wiring. something is loose.
May 29, 2009 | 2003 Yamaha YZ 250 F
Computers & Internet Logo
Top Yamaha Computers & Internet Experts
Tony
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
