Smell coming from old oil heater ,does it need new oil or servicing
  • 604 Answers
Service it,do not use it!!!
Posted on May 05, 2017
Can oil heaters leak as smell comes from old heater and funds?
didnt specify unit---generic answer--yes they can leak and if you smell the oil means their is a leak somewhere most have an access plug
May 05, 2017 | Cars & Trucks
Smell emitting from gas heater
Carbon monoxide is completely odourless and every sort of combustion of a carbon or hydrocarbon fuel produces carbon monoxide. That is why heaters should not be used without adequate and efficient ventilation and heaters should be kept in good order because efficient combustion produces less and inefficient combustion produces more.
Inefficient combustion and the need for service can often be recognised by the characteristic blue flame being tinged with yellow.
Heaters burning inefficiently often produce a smell for the sensitive or stinging eyes but that is not caused by carbon monoxide.
The gas itself is also odourless and the characteristic smell is added to warn people of leaks. I think the added gas smell tends to settle or separate from the liquid gas to some extent so there will be times when it is so concentrated it isn't entirely neutralised by the burning process, at least that is my theory.
Jun 18, 2017 | Heating & Cooling
Pelonis heater smells like burning something
Three possibilities come to mind: First, there may be some foreign objects stuck between the sections of the coils where they connect or in their individual holes, the next is that the cord or outlet in your house is getting too hot (the circuit is being overloaded, perhaps; and finally, the clincher, you have a tiny oil leak in the coils themselves.
Jan 15, 2013 | Pelonis WM-HO202C Oil Filled Radiator...
I just had it installed and smell gas. if it says unvented , does it need vented or am i ok. im 73 yrs old and dont know much about gas heaters
An un-vented heater should never smell like raw gas, you may get an odor of combustion by-products but never raw gas. If you are getting the raw gas smell you either have a gas leak or incomplete combustion. Always follow manufacturers operation instructions that state "open window 1/4" to allow combustion air" If the unit is brand new, you will get an odor for 20 minutes or so of oils burning off of the heater but that smell should go away. Do you have a Carbon monoxide detector in the house? You should!
Feb 13, 2011 | Heating & Cooling
I need to service an everdure gas heater
if you can smell gas and have not done something about it by now then you should not be thinking about diy
gas is more dangerous that electricity simply because if you can smell it it is already an explosive mixture
get in a gas fitter and get a quote to fix
Jun 02, 2017 | Heating & Cooling
I have an oil column heater about two years old, this year it is emitting an adour, is this normal , does the oil get old?
You need to give this heater a good clean with a mild detergent and cloth with it unplugged let it dry for a few hours then try it again. The oil is sealed inside inturn you can't smell this unless it's leaking.
May 30, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
Oil heater won't start
please visit this page for parts:
the service centers should be able to tell you what parts you need.
Apr 08, 2009 | Lakewood 5101 Oil Filled Radiator Heater
Smell of oil in car when heater is turned on
The oil smell may be trapped in the car's cabin air filter.  Locate it and replace it.  Then on a dry day, spray A/C deoderizer (Fridge Fresh) in the cowl area with the heater blowing on high and all four windows open. Repeat a few times in an hour or so, then let it air out well.
Jan 17, 2009 | 2001 Volkswagen Passat
Cold weater start problem. Oil smoke in from the heater vent.
The same problem happened to me and it turned out to be my heater core.
Normally smoke will come from the heater core when it needs to be replaced.
Also the smell is most likely anti-freeze and and you normally smell it when your
engine is running warm or hot.
Check your coolant levels to be sure. and the hoses leading to your Heater Core
heater cores for that vehicle normally run $180 - $230 and you need to remove your
entire Instrument Panel (IP) (Dashboard) to replace it.
I hope this helps!
Dec 27, 2008 | 1997 Cadillac Catera
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
