Top loader water comes out slower than it did
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Kenmore Elite Top Loader reading LD code.
You may have an obstruction in your pump which causes it to drain slower than usual, or binds the impeller. Flow can still be pretty good even with this problem but the brain will sense a longer than normal drain time and flag the error. Try removing the water pump and look for underwires, paper clips or hairpins.
Mar 07, 2010 | Washing Machines
Front Loader Humming
Thats normal just the water valve
Dec 15, 2009 | Samsung WF328AA Front Load Washer
Top loader washing machine does not fill up
very simple, your drain hose is below 4 ft, your drain hose should go in the hole between the hot and cold water, if you dont see a hole then it is covered, you need to knock out the hole...
Nov 10, 2009 | Washing Machines
Water does not switch off automatically when full. It overflows. The machine will not run when the water is turned off at the tap.
If this a front loader machine, the water entry is a timed event. If a top loader, there is a water level switch located on the top of a tube which comes up from the bottom of the outer tub and is near the machine top. The switch is really a pressure switch, which requires no air leakage from the tube or switch to function (the rising water level in the tube generates the needed pressure). Open the machine top to watch what occurs when filling and manually check the operation of the switch.
Oct 24, 2009 | Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Top Loader
try different temp settings be sure screens in inlet valve end of hoses are clean and taps on all the way if you gave water to washer and still none coming in suspect bad fill valve
Sep 03, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
