Question about Sewing Machines
How do i put the key holder back into the key safe. I tried everything but it wont go back in. I COULD NOT loosen the screw in the key holder
  • Sewing Machines Master
  • 11,493 Answers
And this is under the sewing machine category because...
Posted on May 06, 2017
How do i insert a niddle into a singer sew mate machine?
As you're looking at the machine like this, if you look at the top of the needle holder, that is a small, silver screw that comes out to the right. Turn it counter-clockwise to loosen the needle holder and the old needle should slip out. Be sure to insert your new needle with the flat side away from you (toward the back of the machine), until it stops in the holder then tighten the screw again.
Feb 14, 2015 | Singer Sewing Machines
Remove thread jammed in bobbin case holder
Just open carefully the front of the machine (attention where everything has to be put back), identify the problem and try to remove the thread. Inspect the inside of the machine and the lower bobbin case for thread that may be tangled . Take it easy and you will fix it ; most of the times you we'll not need professional help. Post back to tell us where the problem was and how you fixed it.
Sep 29, 2014 | PfaFF Creative 7570
How to put back the part where the needle is attached?
youtube has good videos. Check this link, you will probably be able to see how the part is attached. Brother XL 6562 YouTube
Jul 31, 2014 | Brother XL-6562 Mechanical Sewing Machine
How do i change the needle?
loosen the needle holder screw, remove needle making note of the direction of the flat side if your needle has one. Put new needle up there as far as you can get it... tighten down the needle holder screw.
Aug 04, 2012 | Sewing Machines
The needle on my sewing machine literally just fell off. Not kidding. I'm holding an unbent and otherwise pristine needle. Oh brother SE-270D! I'm not sure how to put the needle back in. I think it just...
when you put the needle in the needle clamp holder the flat side of the needle goes toward the back of the the machine when you tighten the needle clamp screw make sure it's holding the needle,,make sure you can't pull the needle back out of the clamp,, if you can something is wrong with the needle clamp or the screw
Dec 06, 2010 | Brother SE-270D Computerized Sewing...
The book on my consew 226r-2 says to adjust the screw to tighten or loosen tension on the bobbin, I can't see a screw, where is it?
It is usually a little tiny screw on what holds the bobbin in and where the thread passes through the bobbin. (The holder...not the metal or plastic bobbin spool of's sometimes called a shuttle to avoid confussion.) When you tighten or loosen the screw on the bobbin holder it puts more or less pressure on that metal hook the bobbin thread passes through.
Feb 04, 2010 | Consew 226R-1
I burned out the motor of my Bernina 910 sewing machine. After relocating to China, I only checked the presser foot mechancism for 220V. Woops! I need to replace the motor. Please advise if this is...
hi! burn out motor replcement sure can do sure to unplug machine open motor cover downside of hand wheel of motor ,loosen lock screw pull cover if can see belt and motor.loosen motor holder lock screw,adjust motor then pull out belt.underneath bottom of machine cover remove. the terminal chord disconnect, loosen bolt on motor holder and pull out motor replace,putting
back motor reverse what you done in pulling motor. best regard and have a nice day
Apr 03, 2009 | Sewing Machines
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Jan 30, 2009 | Sewing Machines
Needle holder assembly came off
If you look carefully you should see a small allen head screw on the needle clamp assembly. There should be a J shaped part which goes into a hole on the bottom of the assembly. Reassemble everything,put the assembly back on the needle bar and tighten the screw with an allen wrench.
May 21, 2008 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
