Question about Canon Office Equipment & Supplies
I have a canon ir 3530 machine.the problem is machine on but display not on ,indicator light only on . not function the machine
  • 56 Answers
SOURCE: ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Posted on Jan 27, 2008
SOURCE: canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Posted on May 26, 2009
redzventures
  • 149 Answers
SOURCE: I have an IR-3300 Model xerox machine. It was
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
Posted on Jul 31, 2009
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
SOURCE: canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Posted on Aug 16, 2010
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
E000732 0001 error in ir 3530 how can i solve
Official instructions from Canon are these, try if it works for you:
Solution 1:
  • Check all the cables outside of the printer: they must be plugged, especially between the differents elements of the copier:
  • Solution 2:
  • Check all the connectors on the main board.
  • Solution 3:
  • Unplugg and replugg all the leads between the boards and modules
Dec 26, 2016 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Hello i have my machine Ir 3530 i want to change the language from dutch to English
Dear
go to COPIER > OPTION > BODY
<Adjustment method>
XXYYZZAAXX: Country (UP), YY: Language (ja), ZZ(00) Destination,
AA(00): Paper size type
The display contents conform to the display method of
(COPIER>DISPLAY>USER>LANGUAGE). Enclosed in the brackets
are defaults. The country and language are only displayed.
<Operating procedure>
1) Select <CONFIG>.
2) Select an item to reverse its display. Then press the + or - key to change
the contents.
3) Each time the + or - key is pressed, the contents change sequentially.
4) Display the intended contents at all items and press the OK key.
5) Turn the main power switch OFF and ON.
thanks.
Jan 29, 2015 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
JAM ERROR 0207 ON CANON IR 3530
Open the printer and remove the paper jam.
Dec 04, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Sir i have cannon ir 3530 xerox machine that shows 002 my cell no 9833273003
fuser temperature not rising....try to reset in service mode * 28 *, function, clear,err
Dec 12, 2013 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Ir 3530
please cleen your scanner home position sencor
Jun 30, 2013 | Canon ImageRUNNER 3570 Copier/Printer
Display touch is very hard
my printercanon ir 3530 insaid disply was rain water in said but how to open and cleen the disply bord tuch screen
Dec 15, 2012 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Cannon ir 3530 all error code and solution
Code Error name/description
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
old marine
old marine
