Question about Poulan Garden
Belt routing diagram for 46 inch poulan belt keep jumping off
    Master:
  • Poulan Master
  • 645 Answers
The attached drawing is for 46" deck 2 blades.
Posted on Dec 20, 2017
SOURCE: need diagram or instructions on putting on new cutting belt
bex bissell proheat
Posted on May 21, 2009
  • 376 Answers
SOURCE: 46 inch cub cadet mowing deck
Go to... http://www.partstree.com/parts/ Click on the Cub Cadet logo then enter your model number. All the diagrams are there.
Posted on Jun 11, 2009
bschilz
  • 2049 Answers
SOURCE: 2006 Dodge diesel belt routing diagram
Here's a link to the diagram you need...
http://www.gates.com/common/part_locator/view_diagram.cfm?id=S8023
Posted on Sep 23, 2009
Testimonial: "Awesome! thank you so much for the quick response!"
  • 7353 Answers
SOURCE: 1999 ford Taurus serpentine belt routing diagram
http://www.gates.com/common/part_locator/view_diagram.cfm?id=S7021
Posted on Nov 10, 2009
  • 2239 Answers
SOURCE: diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Posted on Jul 05, 2012
What is the diagram for steel deck installation for a poulan lawn tractor 42 " deck 14.5 hp ?
Do a search on goggle for the make model and deck size and you can see the routing diagram.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan lawn tractor 42inch 17.5 hp replace drive belt
us
You can download manual from this site, it should have the belt diagram included.
Jun 06, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Belt diagram for a murray 46 model 46573X92A
This has a couple of diagrams with belts. Hopefully it has what you need. If not let me know and I'll keep looking for you.
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-46573X92A-LAWN-TRACTOR-(1998)-PARTS-LIST.pdf
Jul 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
Primary belt motion belt diagram for a murry 46 inch cut 2006 model
just did another murry today there is a sticker of the belt routing on the bottom of the foot rest
May 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Belt diagram for craftsman 46" model#917258691 I am replacing the secondary belt
belt routing diagrams are sometimes on the underside of the running board [so when you are laying on your back, you can look up and see it, left side usually]. on a 46 inch deck, it's probable that the diagram is on the rear, center of the deck, you can see it by going behind the tractor, kneeling down and looking forward at the deck
Jul 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The newly purchased deck belt turning the blades is extremely loose
If idler is in tact and spring attached, it is likely that the belt isn't routed properly. If you try to route the rear-most portion of the belt around the idler, it will be loose. You must route the front-most portion of the belt around the center blade pully and then around the idler. Just Google "MTD 46 inch deck diagram" and you will go to a Parts Tree site with the proper diagram showing routing.
May 26, 2009 | Mtd Garden
Why does the deck belt keep breaking on Poulan 18.5 hp 42" drive lawn tractor
its possible the belt may not be on the correct pullies. check the diagram and make sure it is routed correctly.the guy i bought my used mower from had same problem. i corrected belt route and have not broke a belt in the two years i've had it
Apr 11, 2009 | Garden
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
