Question about Vizio Televison & Video
Female coax connector broke on vizio smart t.v.can i buy an adapter or reroute out of cable box to t.v.
    Habit-Forming:
  • 84 Answers
If the cable box has an HDMI or video output, use one of them to connect to the TV instead. The female coax connector is not easily repaired and you can't reroute or adapt anything to fix it. You will need to replace the TV main board if the HDMI/video connection is not an option.
Posted on May 19, 2017
How do I connect the coaxial cable?
This is quite simple. Your wall box is a male connector. The TV input is a female one. Make a cable with resp; female and a male connector. Unless the wall box has a 'screw on' connector. (FC10 f.i.) Then you need this special item and/or crimp tools in order to fit this FC type connector to the coax cable. Not simple.
Oct 12, 2014 | Televison & Video
What should I do to make f-pin coax coupler I bought (to link two coax cables to extend the range of my cable box) receive and display cable programs?
Female to female couplers will only connect to a male plug either side. If the two plugs are female you won't be able to do it, till you either change to two males or get a male to male coupler!
Sep 21, 2013 | Cable Wholesale F-Pin Coax Coupler, 1GHz...
Cable adapter on tv broke off
what type of connector is it? screw on? it will need to be repaired. A Cheaper option than some repairs is to buy a decoder box connect the cable to that then use the output from that to your tv scart/hdmi/component etc
Jan 04, 2013 | Vizio L32 32 in. LCD HDTV
Old TV
I can assume the input for your tv has only a coax input to it. Meaning a threaded connector on the back. If so, first connect the Wii to the input of the dvd player, second, from the output of the dvd player, this is where your solution is needed. run a coax cable from the tv to the DVD player and at the dvd player you will need an adapter from your local Radio Shack or electronics store. It should be a female coax to RCA adapter (male Red White and Yellow).Red and white for audio and yellow for video. Post a pic of the back of the tv if this doesnt solve it for you. Good luck, fingers crossed.
Sep 07, 2012 | GE 25GT240 25" TV
I have recently purchased an atari 2600 that came with no rf cable. I understand that using the female phono to male f adapter will work to hook it up, but this leaves me needing to buy the phono cord...
Yes, I know this works because I have done it. I believe both types of cable are the same impedence but different ends so any combination should work. Cheers.
May 14, 2011 | Atari 2600 Console
Satellite/Cable Coax "DTV/TV" in-port broke
Replacing connectors on televisions can be a pricy endeavor. If you can't afford to bring it into a service shop, you may have luck by switching to a different type of connector. If your Satellite or Cable receiver has an HDMI output, your best bet would be to buy an HDMI cable and hook that up instead - the quality would actually be better than coax. Failing that, depending on what kinds of outputs your sat/cable receiver has, you could also go with (in order of preference) component video (a cable with five ends, red/green/blue, plus two for audio), s-video (a round metal connector with four pins in the middle), or composite video (similar to a component video cable, but only three ends - red, white, and yellow).
Any of the above cables (including the HDMI) can usually be found at your local big box electronics retailer for under $30.
May 02, 2011 | Televison & Video
How do you connect to a direct tv box
1st, what kind of Tv Box ? with SCART Connector? or RCA Connector?
2nd, the recoder has a Scart connector or Females Rca connectors.
check for Video IN and L/R input Rca Connector
then use a Scart/RCA cable to connect DVD to TV Box.
Nov 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Dec 28, 2008 | JVC SP-PW100 Subwoofer
Tv coax f connecter is broke off cannot hook cable cord on it. or antenna
I looked up the manual for this TV and it has composite (RED, WHITE, YELLOW) and component (RED, GREEN, BLUE) connectors as well.
Are you using a cable or Dish box? If so, those boxes usually have output in Coax, Composite, and Component formats. You could just run that type of cable. If you use Component you will also need another cable set (RED, WHITE) for audio.
If, on the other hand, you do not have a cable box and you are using your TV's tuner you only have two options. You can repair the broken connector or you can route the Coax through an inexpensive VCR which will allow you to convert it to Composite cables. In this case, however, you'll have to use the tuner in the VCR, not the tuner in the TV to change the channel. Sorry it's not the best of news.
I want you to know that I'm not paid for this. It's a strange hobby I know, but I like to help when I can. While I cannot physically repair you TV, I hope you've found this information at least helpful and will rate it positively. If you have more questions please don't hesitate to ask. Thanks, and good luck.
Jan 03, 2008 | Vizio GV42L 42 in. LCD Television
Sharp 36R-S450 Coax broke off Help!!
it should be alot to fix all u have to do is buy the coax connector n solder it
Oct 28, 2007 | Sharp 36R-S450 36" TV
Televison & Video Logo
64 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
