What do i do when my keys milestone 2200 treadmill is stuck on pause. I turned on... Pause shows.... hit pause... still pause... turned off... pause... unplugged... pause
Noggin
  • 944 Answers
SOURCE: I need to reset the washer; after pausing to add clothes it is messed up.
Here is the manual if you need it; http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=WCVH6260FGG page 7 and 11 says that pressing start/pause again once the door is shut should restart the cycle. If you have had no luck with this then possibly there is a problem with the washer pump filter - GE claim this is not user servicable and i haven't been able to find exact instructions - usually this would be behind the panel at the bottom of the front (this should click off but check before you break anything) there should be a small (3-4 inch) screw plug which can be undone to check the filter. GE may be telling the truth though and it may be inside the machine and hard to get to. Unfortunately I think you may need to get a service man to look at it - it sounds like the controller may have died Phone GE on 1-800-626-2005 and ask - maybe others have had this problem Hope this helps
Posted on Mar 08, 2007
SOURCE: repeat keys and back space has pause when typing
I fixed it by completely restoring my computer...thanks for your help...
Posted on Mar 12, 2007
  • 67 Answers
SOURCE: paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
Posted on Mar 20, 2007
SOURCE: pausing printer
Try enlarging your "Printer Buffer" if you can.. OR maybe you need to set your Parallel Port to a differsnt mode in the BIOS. And/Or try updating your "Drivers" see if this all helps.
Posted on Jul 24, 2007
  • 1314 Answers
SOURCE: Washer stuck on Pause mode
Remove the washer from the electrical supply.
2. Remove the top panel and disconnect the wire plug to the pressure sensor.
3. Reconnect the washer to the electrical supply.
4. Press start and wait 10 seconds (washer will drop out of the continuous loop).
5. Remove the washer from the electrical supply.
6. Reconnect wire plug to pressure sensor and reinstall the top panel.
7. Reconnect the washer to the electrical supply and verify proper functionality.
8. If same symptoms occur, install a new console control.
Posted on Dec 30, 2007
How to access to life fitness treadmill 95te menu
Hold down the PAUSE Key and press CLEAR Key twice. Continue to hold the PAUSE Key until the SERVICE MENU appears. Use the Speed UP/DOWN key to scroll through the menus and the ENTER key to make a selection. Once finished CLEAR button twice will reset the machine for use.
Oct 09, 2013 | Life Fitness 95Te Treadmill
Treadmill says fill with wax
Diagnostics is entered by holding the 'PAUSE' key when power is applied or by holding the
'PAUSE' key and pressing the 'CLEAR' key twice from any state.
The unit will take approx. 3 to 4 seconds to enter Diagnostics.
On entry to this state, the message:
USE ARROW KEY TO SCROLL THROUGH LIST till show on ddisplay the option "MAINTENANCE"
USE ARROW KEY TO SCROLL THROUGH LIST when display show the message "replace wax bag" press enter
the display show "repair logged" and exit press the key "clear"
Feb 05, 2013 | Life Fitness 91Ti Treadmill
How do u diganose engine codes on a 1985 dodge 600 se 2.2
If you have an obd reader, there is a wire under the hood on the passenger side where obd connector can be plugged
Aug 26, 2010 | 1985 Dodge 600
Sx4t labels gap setting
1. Press the [PAUSE] button. The display shows the printer is in PAUSE mode.
2. Press the [PAUSE] button again. If the display shows TRANSMISSIVE then release the [PAUSE] key.
3. Press the [PAUSE] button again. Labels will now start to feed through the printhead. After 5 or 6 labels have gone through, release the [PAUSE] key.
4. Press the [RESTART] button.
The printer should now be on line and if you press the [FEED} key, 1 label should be fed through.
Aug 21, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
How do I access the service menu on a lifefitness 9500HR treadmill?
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
Mar 31, 2010 | Life Fitness 9500HR Next Generation...
Communication timeout message on a display
You need to press and hold Pause,press clear twice. Continue to hold pause until the display reads SERVICE MENU. Press any up arrow and select SYSTEM TEST. then press enter in the desired mode,then the display will scroll automatically though available options. You want the first option which is SYSTEM COMM TEST hit enter upon do so it will perform test to communicate with all module within the treadmill. If a module does not respond to the upper console the a error message will display.
Mar 15, 2010 | Life Fitness 9500HR Next Generation...
My remote is stuck on pause. There is a pause
Sounds like the still is engaged hit the button again to turn it off.
Mar 14, 2010 | Televison & Video
How can i enter in manufacturers configuration menu on Lifefitness treadmill 97ti
To enter the Manager's Configuration, press and hold down the PAUSE key and press the
CLEAR key twice. Continue to hold down the PAUSE key until the MESSAGE CENTER displays
the words “SERVICE MENU”. Then, release the PAUSE key, press the QUICK START
key, and press ENTER. The MESSAGE CENTER then displays, in turn, each of the configuration
settings.
Jan 14, 2010 | Life Fitness 9100 Next Generation...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
