Question about Vizio Televison & Video
Vizio , model xvt473sv that will work for 10 min. then the picture goes out and have sound only. I replaced T-con board from shop jimmy but have the same issue sound but no picture when tv sits and cools down the picture and sound will come back but after 10 min I loose the picture again ? fuse ?
SOURCE: tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Posted on Apr 16, 2008
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
SOURCE: plasma tv picture goes on and off but always has sound
I install a fan in the back, there is a only o9ne 5 v, 3,3 a that you can connect workin fine..
Posted on Apr 14, 2009
TODDAS
  • 431 Answers
SOURCE: Vizio SV470M Issue Sound No Picture
Do you have backlight? If you do, you have a bad main logic board. Very common with vizio and are hard to find. They are usually out of stock everywhere.
Posted on Oct 31, 2011
bugoy31
  • 1238 Answers
SOURCE: vizio m420nv has sound but no picture
Hello there
Actually that problem is very common on all LCD TV,, that problem is cause of either inverter board or t-con..
In this case you don't need to check the voltage that is too complicated for you,,only visual check is enough..
I share you my tricks and hope it helps..
Power on your TV turn off your lights..if you will see the light comes from the screen the problem is t-con..if no light the problem is inverter board (backlight) board
Hope it helps..
Don't forget to rate..
Posted on Aug 25, 2012
MY VIZIO M50-C1 TV BROKE, AND I NEED A LITTLE HELP. I REPLACED THE POWER BOARD ON IT AND THE SAME THING STILL HAPPENS.
If you have no picture and no sound, go with the main board first since that board works with both. If you have sound try the t con board first since it specializes in the video that appears on our screen..
Mar 22, 2017 | Vizio Televison & Video
Jimmy shop.ccom has T-con board part #T500HVD0.0 500t10-C02 at the bottom in the description it list model PLDED5030A CRk my model is PLDED5066A-E since the parts # the same will it work in my tv?
If you see an image with a flashlight the T con board and power supply board are good. The back light controller board is the culprit.
Dec 18, 2015 | Televison & Video
Only white light shows with a high pitched noise. No picture. No sound. Dark screen and nothing works. It is a vizio xvt473sv. Help!
Suspects shorted inverter transformer at its back-light inverter board. The back light inverter board might replaced. Contact any service technician. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 02, 2013 | Vizio XVT473SV 47 in. LCD HDTV
Vizio xvt473sv sound, but no picture (displays glows)
are you using a cable box? tried to reset first. if still the same problem, at this time you will need to remove the back cover to access the internal part. then look for the screen back light which need replacement.
Oct 16, 2012 | Vizio XVT473SV 47 in. LCD HDTV
. Problem with Projection Televisions Cust.
Good day!!!
That problem is usually cause of bad T-con LED controller TV board (T-con board is the responsible for processing of picture on your TV)..
This is the sample image of T-con board.
I suggest you to buy this TV part to fix your unit..
I already search the board online so you don't need to spend more time for searching parts online..
Try to click this link:
http://www.shopjimmy.com/vizio-3647-0032-0147-pc-board.htm
http://www.tristatemodule.com/p-20461-3647-0032-0147-vizio-tv-module-t-con-lcd-control-0171-2372-0024-xvt473sv.aspx
http://www.rivervalleyelectronics.net/Vizio_3647_0032_0147_T_Con_LCD_Controller_p/3647-0032-0147.htm
Hope it helps...
Thank you for using fixya..
Jan 13, 2012 | Vizio Televison & Video
I have a Vizio L37. When I turn on the TV it works perfectly after about 3 minutes the screen goes to green (no picture). However I still have the sound.
My first guess would be your t-con board. The t-con board is the one that transfers teh picture from your signal board to your screen. My second guess would be the siganl board is bad.
You can get parts at www.interliquidparts.com
Nov 29, 2011 | Vizio L37 Television
Westinghouse ltv-46w1hd I have sound no picture was advise it could be the backlight inverter how can you tell if it bad.
I have a Westinghouse 46" LTV-46w1 HD and it turned out to be the T-Con board which I found a used replacement board at Shop Jimmy’s. It cost around $70.00 with shipping. My TV was purchased in 2006 and it running better than ever… again!
May 19, 2010 | Vizio VW32L 32 in. LCD HDTV
The screen is just white
t-con board has failed very hard to get parts try shop jimmy .com
Sep 18, 2009 | Vizio VX37L Television
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
