FixYa.com
Tags:
Rainbow E series Canister Wet/Dry Vacuum
D3 Rainbow Vacuum separator problem (by 2 users)
posted by d_de on Nov 21, 2007
I have an older Rainbow d3 series vacuum. One day while running, the hose sucked onto something and I heard a pop. On checking I found that the separator had broken. I replaced it with a new one. When I started the vacuum it ran great for about 3 mins. until I again heard a pop. The separator had broken again. Any idea what could be causing this and what to do to fix it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by ray_s51, posted on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off the motor seams to make a loud squealing noise. Do I need to oil something or what? Thanks
Best Solution
posted on Jan 18, 2008
Helpful (85)
bradwick1
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
something loose underneath the separator?
Comment by bradwick1, posted on Jan 18, 2008
there is a nut under the separator that may be loose. or possibly the screws holding the motor housing have come loose putting it off center.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Vacuums
how to use air pump
how to use air pump attachment... Answer This...
Vacuums
wand
my extension wand wont slide... Answer This...
Rainbow Shampooer
Where do the two tubes go at... Answer This...
Rainbow E Series
Hello...I read your answer to... Answer This...
Rainbow Rainmate
I have a Rainbow Rainmate with... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
