THERE IS NO AUX INPUTS HOW DO I HOOKUP MY RECIEVER UP FOR SURROUND SOUND?
MakikiChris
  • 84 Answers
SOURCE: Surround sound problems.
Dolby 5.1 is not supported via either of the Aux inputs. Be sure to check your main menu/audio setup screen to ensure that "stereo" is not selected. If it is, DVD's will not downmix, giving you only 2.1 stereo.
Posted on Jul 31, 2007
  • 3 Answers
SOURCE: Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Posted on Dec 14, 2007
SOURCE: yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Posted on Jun 12, 2008
Dooms Day
SOURCE: surround sound hookup
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Posted on Jan 04, 2009
daniel719
  • 240 Answers
SOURCE: Adding another external device to the sound system
yes you are right you can pick up an arc aux swich box from radio shack.
will do your job just fine.
thanks
and pleas rate this, if is of help to you.
Posted on Jan 13, 2009
I cannot get my coby surround sound to turn down.
whatever your watching you have the red and white audio cables put in the wrong input on your reciever...if your runny cables anywhere from something to your reciver it has to be in aux 1 or aux 2 the one you have it plugged into is where you hook your reciever directly up to your tv
Nov 06, 2010 | Kitchen Ranges
I cant figure out how to get my playstations 3's audio to play through my koss surround sound
Hook your video source up to the display (TV), and run your audio cables to an input on your surround sound receiver. Note which input the audio cables are hooked up to and set the surround sound receiver to that channel on the front of the receiver. For example, if you hook up the audio inputs to "AUX" in, then make sure you select "AUX" on the front of the receiver. If you hook up the audio input to "DVD" on rear of receiver, make sure you select "DVD" on the front of the receiver. The connections on the rear of the receiver have to match the selection on the front of the receiver. Make sure that the cables are hooked up to "INPUT" on the surround sound receiver. It doesn't matter how the inputs are labeled (DVD, AUX, etc.) they all do the same thing. Check volume and mute controls on receiver as well. I know it sounds trivial, but sometimes it's the little things that get overlooked and cause problems. I hope this helps and good luck.
Oct 28, 2009 | Audio Players & Recorders
How you hokup sound system to the TV TP6190
on the back of the t/v connect RCA cables to the audio out (right-left) then plug the other end of the RCA cables to the input of your reciever or amp ( t/v input-aux input-vcr input any of the inputs will work but DON"T use the phono input!!
Dec 19, 2008 | Toshiba TP61G90 61" Rear Projection...
Hookup my surround sound
for verizon cable box to system
Dec 18, 2008 | Onkyo TX-SR803 Receiver
How do i connect my subwoofer to my sony dvd player to get the great surround sound?
there will be a subwoofer pre out( needs to be amplified) or if it don't have subwoofer pre out you will have to send the audio out to a stereo reciever that has inputs for the optical ( digital audio signal )( to a stereo or surround system that has 5.1 or higher has full surround sound ) and of course L and R audio inputs and the subwoofer pre out , then the subwoofer pre out will have to be amplified by a reciever , subwoofer amp , surround sound , ect
Oct 17, 2008 | Televison & Video
Panasonic SC-Pt 660
I fixed the main problem. It has inputs, not labeled as such. one set right next to all the outputs labeled only aux.after plugging in to the TV outputs, and putting the unit on AUX, this was fixed. The surround speakers were harder to work out, After downloading the manual, I was able to get sound out of them, however at a lower level than all the others. Even following the speaker level adjustments in the manual, cant get more volume out of them...I'll keep trying.
May 26, 2008 | Panasonic Home Theater System System
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Dec 07, 2006 | GE GTD120 System
DVD SUrround SOund Help
Ensure that there are no conductive material's (metallic thread, fine wire such as shielding braid)near your Aux inputs that may be shorting your connections. You could also try using an emory board or fine sand paper, or even a pot scrubber on your inputs and RCA plugs in case it's just simply dirty and hampering the connectivity.
Aug 18, 2006 | GE GTD120 System
 Grubhead
Grubhead
