My oyster satellite system is showing fault code EO5 and the dish doesn't even try to come out to play ?? What's its issue ???
4 Suggested Answers
johnsonr1
  • 91 Answers
SOURCE: error code EO5
I am assuming that the manufature is Master Temp by Pentair. Is this correct? If so, the manual for it can be found here:
http://www.staritepool.com/pdfs/MasterTempOM.pdf
Posted on Aug 22, 2009
BElectric
  • 1140 Answers
SOURCE: I am trying to connect an Insignia flat panel TV
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Posted on Dec 29, 2010
eminemfan31
  • 10 Answers
SOURCE: ps3 fault code 8001002b
try factory reset
Posted on Aug 23, 2012
Oyster satellite dish wont go up it just saying Y Blocked
Get a small pointed screw driver and check that
the plug /wire connections into the plug going into the control box are all pushed in oK.
Also you might have low battery voltage, run the engine for 10-15 mins to charge the battery.
It is possible to fold the dish manually by getting on the roof and undoing the two bolts one either side then folding the dish down and re doing the bolts tight in order to stop the wind getting under it.
Sep 29, 2014 | Computers & Internet
We have dish network. the problem is the picture doesn't fill the screen. it just shows up in a small box. what can i try?
On your DISH remote press the format button with an asterisk on it if this doesn't correct the issue try the page up and page down buttons to the right of the volume. If neither of these correct the issue reply with your receiver model number and we can go from there!
Daniel Busa
DISH Network
Customer Service
May 25, 2011 | Vizio 42 in. LCD TV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Hello- using dish 500 with twin lnbf, 311 receiver. 119 locked in easy with 70 signal . When trying to find 110, I cannot get a strong enough signal to lock. 129 signal shows strong along bottom of point...
Hi CharlieO my name is Mike of DISH Network and I was reading over your post and seenwhere your 110 satellite is not locking in or on your install summary screen. Iwould be more than happy to help with this issue and to research further I willneed to look at the account to look what satellites they have setup on youraccount. I will need your account number or your phone number; I will leave mye-mail so you can contact me directly. Michael.houston@dishnetwork.com
Jan 30, 2011 | RCA DISH Network(r) 311 Satellite System
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
May 23, 2009 | Syntax Olevia 537H Television
Trying to find out what my tvs settings should be on to hook up m
Have you tried channel 3 or the video input channels.
The Tv only needs the one channel that the signal from the box is sent on.
All the viewing channels will be changed through the satellite box.
May 11, 2009 | LG Televison & Video
My Sky system says there is no satellite signal being received. Have tried disconnecting box etc with no improvement.What else can I do?
press services then system set up then signal test the signal strenth and qaulity should be about half way at least it shows up grey lock indicator should be ok if it shows not locked your dish has been moved and needs to be alighned do this when the weather is fine clounds and rain reduce the signal and may even stop it all together sky will charge you £65 to alighn the dish but you can buy a meter and do your self get 1 from bandq ebay maplins worth checking for breakes in the cable going from your box to the dish and if you can try your box on a friends dish just to rule out a faulty box of course there is a chance the lnb on the dish has gone faulty but you can get these cheap to or even borrow a friends to try unscrew the cable and look how it is fixed on useualy they just pull of but it might have a clip on or tape on
Aug 24, 2008 | Televison & Video
Dish Network - Dish 500 Satellite 110 is not being recognized
chances are that you have only lined up the dish to pick up one satellite. there are several satellites up there for dish and its easy to miss the ones that you need. try to line up the dish keeping this in mind. if that doesn't work, write back.
Apr 30, 2008 | Televison & Video
Innovage jumbo universal remote code
try this website, you have to scroll down and find "Innovage" on the list and then it will download the pdf of the manual.
http://www.xdiv.com/remotes/
Dec 28, 2007 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
