Question about IBM ThinkPad T30 2366 Notebook
Substitute keyboard for t30 - IBM ThinkPad T30 2366 Notebook
  • IBM Master
  • 32,281 Answers
Replacement keyboards for laptops are available on the Internet.
I purchased one from Yall Store
Use this link :-
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Posted on Jul 25, 2009
No fn key on my inland pro usb keyboard what is the fn key substitute
Reference to a Fn key means any function (F) key. For example, Fn = F8 where n=8
Feb 25, 2013 | Inland Pro Usb Keyboard
I have a T30 and my keyboard will not use or maybe say I cannot use the following keys r,t,y,u,f,g,h,j,v,b,n,m. The one I use at work is a T43 and this model is a little different. If you could help, that...
To quickly identify if the keyboard/ribbon is at fault, connect an external USB keyboard and see if problem still exists.
If so, replace on-board keyboard.
Apr 04, 2011 | IBM ThinkPad T30 2366 Notebook
T30 keyboard gives * instead of p, same for m,j,k,l,u,i,o
Solutions to your problem:
1. Reinstall your keyboard driver which might have got corrupted.
2. CALL IBM service center ppl and ask them to replace your keyboard.
~regards,
Jegan
May 16, 2009 | IBM ThinkPad T30 2366 Notebook
Have an IBM ThinkPad T30 2366 Notebook. Windows boots up. I do the normal Ctrl-Alt-Del and then presented with Windows login screen. My problem is that 1 letter on each row of the keyboard does not work...
Hi there.
Keyboards tend to do this from time to time, and is quite common.
You can use a USB keyboard to access your PC until you have a replacement keyboard for the laptop.
If the USB keyboard is not recognized hit F2 (on start up), enter the bios and set it to defaults, save the changes and exit, the computer will restart and you should be able to use a USB keyboard to access your account.
Good luck and thanks for using FixYa!!
May 14, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thnikpad t30 bios password problem
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
Feb 21, 2009 | IBM ThinkPad T30 2366 Notebook
Removing password on T30
YES.... providing that the hard drive was not completely re-formated before the windows OS was installed.
Usually, manufacturers leave a section of the HD for this so in the event that something goes wrong, you would be abke to revert back to the manufacturer's setup.
Simply follow the following instructions... :
1) remove power from the T30.
2) hold or tap the 'G' key on the keyboard
3) apply power back on T30 while maintaining step 2)
4) turn on T30 via power button while maintaining step 2)
5) T30 should eventually boot up and in factory default settings.
If this doesn't work, repeat process or the T30 was configured to disable the 'G' key. In this case you need to reflash the firmware on the T30.
Aug 29, 2008 | Compaq EVO T30 Network Terminal
Ibm t30 keyboard stuck in odd mode
You've activated Euro mode. This is toggled by pressing holding the Fn key plus an Fkey that has an icon in the same color as the lettering on the Fn key that looks like the Euro symbol. Press the Fn key plus the Euro key to toggle out of Euro mode.
Regards,
Worldvet
Aug 03, 2008 | IBM ThinkPad T30 2366 Notebook
T30 Power up problem
The c-mos won't cause this. The power button is integrated into the keyboard, and uses the same connector as the keyboard to get power to the system. In most cases, the board with the power button (which is part of the keyboard) is worn out. Occassionally the keyboard connector will work loose or get a little corrosion or dirt and not make a good contact, check and clean the connection. If the connection is good, then I'm afraid you will need to replace the keyboard in order to cure the problem.
Jul 15, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
59 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
