Question about Singer Sewing Machines
How do I fix slanted stitches from a singer Quantum Stylist Touch
Stitches are slanted, not straight. The holes are in a straight line when stitching on paper without thread
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 23 Answers
SOURCE: Button hole maker on Singer Quantum Futura CE-200
Try to adjust the stich width on the machine maybe it can help
Posted on Mar 31, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
SOURCE: Bobbin stitch is loopy
4 is the "middle of the road" tension number, but it depends on the thickness of your fabric.
Posted on Jun 15, 2009
Zenqi
  • 208 Answers
SOURCE: My brand new Kenmore serger
The loopers must be threaded before the needles.
Make sure that the needles are not threaded. Thread the loopers and have the loose ends behind the presser foot. Then re-thread the needles and place a scrap of fabric under the foot and sew. Make sure that the edge of the fabric is not to the right of the plate, but where it would be if the knife had cut it.
Posted on Jun 17, 2009
I have a singer quantum xl-1. The needle bar won't go down when any of the pictures are selected to sew, duck bear. The letters work and all the straight stitches and zigzags. Any ideas?
Hi Karen,
Looks like your machine is stuck in needle bar lock out (or basting stitch) mode. There is a small rubber pad that the top of the needle bar hits when the needle bar is locked out. If the pad is missing the bar will stay locked out.
You can manually pull down on the needle bar in regular sewing to get it going again. But it won't do the Maxi, or basting stitches until it is fixed.
good luck!
Oct 29, 2016 | Singer Sewing Machines
How to change needle position (left, right, center)
Which stitch are you using? As far as I can tell, the Stylist 7258 only allows you to change the needle position for straight stitches. If the machine is set to Pattern 00, press the right or left buttons from the 4 arrow keys in the manual setting arrows until the needle is in the desired position.
For all other stitches, the left/right arrows adjust the stitch width. This is described on page 30 (in English) of the manual. You can download the manual from the product page under the support tab: http://www.singerco.com/products/2101/7258-stylist#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/4951b452e963a8fe1dd1fd83fbac68a35df8cf19.pdf .
I hope this helps.
May 23, 2016 | Singer Stylist 7258 Electric Sewing...
Where do I take my sewing machine to get fixed?
sadly we have no idea where you live , so we can not check for you. try the singer website at singerco com
May 13, 2016 | Singer Sewing Co 7258.CL Stylist Sewing...
Singer sewing machine is stitching every half inch how to fix this
I had a singer machine that had a basting stitch that was like that. Make sure that you have chosen regular straight stitch.
Feb 12, 2013 | Singer 2639
Singer Stylist 11 Serger problems with right need skipping stitches how can I solve the problem
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
Jan 04, 2013 | Sewing Machines
My sewing machine is not sewing stitches
That is irritating! Singer has your manual; check out: http://www.singerco.com/accessories/manuals.html
I believe it costs $15.00.
Happy sewing!
Robbie
Jan 29, 2010 | Singer Quantum XL-6000 Computerized Sewing...
Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Aug 19, 2009 | Singer Electronic Sewing Machine
Tension problems
Hi, check that the thread tension knob makes only one rotation from 0 to 9 and stops at each ends, see that it moves in and out as you increase or decrease the tention, see that the small tension wire to the left of the knob is still in place, in any of these fail you need to replace/repair that assembly.
Aug 11, 2009 | Singer 7462 Mechanical Sewing Machine
May 08, 2008 | Sewing Machines
Sewing Machines Logo
23 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
