Samsung 32 2 years old
I got a samsun 32'' flat tv and it takes many times to turn on, i can hear the melody that it does when is tryin to turn on but it takes many times to do it, even minutes and i can see that it takes more and more time to turn on?? whay i this??
  • 585 Answers
Could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost a few dollars only that way
Posted on Aug 01, 2009
Sound dose not work
Either a bad main pcb or bad speakers. Do you hear a melody when the set is turned on or off?
Mar 18, 2014 | Samsung LN22C450 22 in TV
Tip
Turning off the Melody sound on a Samsung Television.
You have a Samsung television and you want to turn it on at night, and not wake up your house, or you are annoyed by the sound that the television makes when you turn the set on and off. Samsung incorporated a feature into the set that will play a melody to let you know that the set is either turning on or off, whichever the case may be.
If you want to turn off the melody you can follow the instructions below and that should take care of the annoying sound that is bugging you.
You may have a Samsung television and you remember when it had a melody when you turned it on and off and now that is gone. Well this tip can help you too. The same menu selection will allow you to enable the melody that is missing, and you can bring it back.
You can change the setting on your Samsung Television by selecting “Menu” then “Settings” and arrow down to “Melody”. There are four options; Off, Low, Medium, High. I personally would not select the high setting as it is very loud on my set. I guess if you have someone in your house that sneaks the television on and you want the loud melody to play, this could be a way of knowing when the set comes on. I hope that this helps you with your television issues and as always, Thank you for using FixYa.
I hope that you enjoy your television for years to come.
asnowman
on Mar 16, 2010 | Televison & Video
My Samsung LN32D450 has sound no pix. it's only 1.5 years old
it could be a backlight problem. Try this, dim the lights in the room, turn the set on. Take a bright flashlight and shine it on the screen. If you see a faint image on the panel, you have a backlight fault.
Jan 10, 2013 | Samsung 32 LN32D450 32 LCD TV
Samsung 32'' LCD TV backlight works occasionally
Check for any loose soder points or loose connections with wiring sockets to backlight inverter board.
Apr 20, 2012 | Samsung LA32B450 32 in. TV
TV will not turn on. It just clicks.
RELAY is clicking noise you hear.FUSE IS GOOD!!
Power supply problem.
May 19, 2010 | Samsung LN-T4665F 46 in. LCD Television
Samsung flat screen T.V with sound problems.
Sounds like the issue is with the set top box of your cable or direct tv provider. Please swap that receiver for the equivalent or a more updated version.If the problem persists. Verify that all inputs on television is correct. It should match. Output of source( digital receiver,dvd player) to Input( television ). Make sure all is secure. Good luck
Jan 31, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
How do i turn chime off when you turn tv on?
go into your tv menu probably under setup for audio you will find a reference to "melody" turning that to off should do the trick.
Jan 21, 2010 | Samsung LN-S3251D 32 in. LCD HDTV
The volume is not working on our Samsung HPT4254 Plasma. We have a RCA surround sound connected to it as well as our cable box.
First check to make sure that the audio isn't "Muted". Second, Go into the user menu and check to make sure that the "Melody or Chime " is turned "on". Third, Turn the volume up half way.Fourth, Turn "off" the set. You should hear a "Down" Melody or chime. Next turn "on" the set. If you did hear the Melody when you turn the set "on" or "off" then the audio system in the set is ok. If you did not hear the Melody then the Main bd needs to be replaced. Have a trained Samsung tech repair your set.
Jul 12, 2009 | Samsung HP-T4254 42 in. Plasma Television
Samsung 40 INCH TFT-LCD Cant start up at all .
The noise you are hearing is the power supply attempting to start up. Unfortunately, a component has failed inside the power supply circuit. Most likely it is a capacitor. The good news is that the set should still be under warranty and the repair should not cost you anything. The bad news, is that the service person may not have a replacement power supply board with him/her when he/she arrives. This should be a quick fix as the replacement board is relatively easy to change.
Dan
Feb 04, 2009 | Philips Televison & Video
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
